Losi XXX-S
#5251
What difference does the TITanium Turnbuckles make? and the TItanium HIngepins?
#5252
Originally posted by ChrisO
how long u been racin? [/B]
#5253
#5254
Originally posted by KevanB
what setup should i use in an all graphite xxx-s? I havent bought it yet, and i only have an Explorer 2, and a P2k2, and only ONE battery (2500, besides my 2 1500 packs)
I tried racing with my rally, and it didnt turn out so well ,as one battery is hard to run in all the races and qualifiers. Do you reccomend a Pro Match 3000 HV battery?
I will only have about 30 dollars left when i buy the xxx-s, so i probably cant afford any accessories yet besides a body.
#5256
hey can someone help me on this!?!?!
#5257
R/C Tech Founder
He actually got a used XXX-S car, all graphite. Not the G+. It was a pretty killer deal. I agree though, it's best to allocate money wherever it will best be spent. I think he's doing a good job...
But yea, to race effectively (for a 3 Q + Main program) you need 3 packs at the bare minimum. 3000s or 3300s ideally.
#5258
No doubt futureal, Sanyo, Panasonic or GP 3000/3300 mAH's are ideal for racing right now, forgot to add that. Kevan, Finding a setup from someone isn't the whole point to winning races, it's learning how to setup a car to make it fast. Don't get me wrong Kevan, you can put a setup on a car that is just totally screwed to hell and back if you don't know what does what(caster,camber,shock travel, tires, list goes on and on), so start with the manual setup and go from there. Ask as many questions as you can at your track, here on RCTech(best RC forum around)about what does what so you can use that info to help setup your car, don't talk to the guys placing 9th in the C main every race day, talk to the fast guys and ask questions twice to differant racers so you can compare answers. If your serious about racing then theoretically you want to learn how to setup a car, you're already thrilled about driving it, now learn how to tune it so that you can drive it. The back of the XXXS manual is a great starting point for learning the adjustments.
#5259
Busted a front shock shaft on the graphite plus during our mains yesterday, it is unbelievable how much the front upper bumper brace has to move to even hit the shock. I'm gonna try Rayhuang trick with the dremel, anyone else have other ideas to fix this. On another note, why does the rear diff after several hard runs feel gritty and when checked 5 to 10 minutes later it is smooth again.
#5260
i broke a shock shaft today how does the bumper reach that shock so far in?
#5262
This make four front shafts broken since I got the car. Is this bumper the real problem or is it the shafts? I'm putting on all of the regular shafts and taking this front bumper thing off of the car. I ran stock yesterday and barely brushed up against the boards and my shaft was broken. We'll see what happens next weekend....but I don't plan on crashing
#5263
Thanks, Kraig but how much of a difference does the aluminum belt cover makes besides showing off! HEHE...
#5264
R/C Tech Founder
It strikes fear into the hearts of your opponents.
#5265
Originally posted by tufferwilde
OK -
Since we are all talking about the G+.... how about the crappy Front shock shafts included in the car? How many others out there have broken the shafts?? Thus far, I have broken one each week... but I am hesitant to put another batch of Ti Nitride shafts on the car if this is a running issue with the latest shafts...
I also recently read on TT that the shafts were having this issue somewhat due to the new upper bumper mount hitting the shock... but... The last shaft I broke broke just as the other did at the top thread of the shaft... the bumper didn't take the hit... the left front did - in fact I ripped it off! But just the same - in similar crashes, I haven't broken shafts on my asphalt car (identically equipped XXX-S - not G+)
I am going to put the UGLY BRP bumper on the car this week in an effort to save the time and hassle of building the shocks, measuring, etc!
OUT -
Wilde
OK -
OUT -
Wilde
Originally posted by rayhuang
Me-I did it!!! Head-on hit, didnt hit a wheel. I think the top of the bumper smacked the shock. Add on top of that a possibly too hardened shock shaft or possible poorly machined shock shaft and "snap".
Originally posted by STLNLST
I went through two shafts in two laps. I 'll replace them with the stock one's if I should happen to break another one. No broken arm or any other part. The shaft broke right above the threads.
Just out of curiosity, are you all threading on your shock ends by holding the shock shaft with some wire cutters right above the top of threads?
