Tamiya TA05MS
#771
I never raced my MRE in stock. It was good in 19T but I had consistent problems with it. In stock, I ran an MSX that was converted to MRE spec with the exception of the steering (a car I had been winning with consistently). I raced that MSX back-to-back with the TA05MS a few weeks ago and i went .1 faster with the MS on it's first run then I did with the MSX. I like it alot plus I feel the drivetrain is a little freer. Lipos fit in it a lot easier too. No mods necessary
#774
After some testing and races, here's what seemed to work for me.
For tight tracks 23T stock
Reversible sus arms (short type)
No sways
2degree caster
front ball diff
Front 1degree toe out(sus blocks F:1B, R:XC) Rear 1.5toe in
RP 36 w/ yokomo medium inserts
Raise rear roll center with spacers
rebound 4mm F/R (Still experimenting)
Springs, oil: kit stock
Little twitchy, but rotates very well. If you're used to driving pan cars, no biggie here. Track is relatively clean asphalt with sugar water. May need more rear toe with unprepped surface.
No sways
2degree caster
front ball diff
#776
Sounds Good
No sways
2degree caster
front ball diff
No sways
2degree caster
front ball diff
#777
redbones, nice setup you have there but why is it twitchy?
try putting on the sways that came in the kit but do not tighten the one in front though but the one in the rear, yes.
Rear toe-in should atleast in box stock setup and your front toe-out is just right.
Try using a spool instead of ball diff up front. then ball diff at the rear.
Rebound stroke, try using the box stock setup. Then sus. tension atleast try making your ride height 5mm in front and 5.5mm in rear. Shock oil, that came in the kit.
This is somewhat same with my setup and I didnt have any problems with twitching whatsoever and it was good in cornerings, but I was using a oneway that time...
Actually, to summarize what I have just said in this message, I used the stock setup that it said in the manual and just make some minor changes like the sways, and suspension tension. HTH's to remove your twitching problem...
#778
No sways
2degree caster
front ball diff
No sways
2degree caster
front ball diff
#779
you may be able to use arms, towers and other minor stuff.
#780
Thanks for the comments guys. Yes, this track is rather small and has a lot of haripins. Cornering speed is the key on these tracks so I deviated pretty far from stock setup. On top of all the setups, I also shortened the wheel base about 4mm. The front ball diff is so I can go hot into a corner, brake hard, turn, and mash the throttle out. It's fun when I'm being chased by someone and they start to drive at my pace. Most of the guys use a one-way, if they follow me into a turn the way I do, spinning they go. I say it's twitchy because my friends can't drive this car lol. I think it's just fine.
