Like Tree1Likes
JL Racing .12
Old 02-01-2008, 09:48 PM
  #1141
aussies1129's Avatar
Trader Rating: 74 (100%+)
this has probably been answered before but anyway I have a short tight track whats the better pipe the skyline or picco?for the evo 2 and evo 3?
cheers
aussies1129 is offline
Old 02-01-2008, 11:47 PM
  #1142
Team Kamikaze's Avatar
cheers
Michael,
PICCO 2607 pipe for both JL2 and JL3.
Team Kamikaze is offline
Old 02-02-2008, 12:46 AM
  #1143
Originally Posted by Team Kamikaze
Michael,
thanks for the info Sam I will be getting one from you this month and another JLR evo3. could you message me a quote for this with shipping JLR evo3 and picco 2607 pipe and manifold and shipping to australia, and by the way my friend got his evo 3 I ordered from you the other day and he loves it!thanks for your service!
cheers
Old 02-02-2008, 04:02 AM
  #1144
stefan's Avatar
I suggest you buy a JL EVO 3, so you can measure the crankshaft's I.D./BORE and see the actual measurement yourself.
for short Show it to yourself!
I got one and it does not have the big bore crank.
stefan is offline
Old 02-02-2008, 07:28 AM
  #1145
Perhaps the crank is bigger only on the JLs and not on the non-JL Piccos. I have both engines, I will check too.
nitrodude is offline
Old 02-03-2008, 05:13 PM
  #1146
Trader Rating: 15 (94%+)
Default pipe comparisons
Hi all
im just wanting some info about the pipe comparisons below for red dot evo 3
picco 2607 vs the novarossi 2630?
i race on a large flowing track with a long straight and some tight short turns
mrgsr is offline
Old 02-03-2008, 05:20 PM
  #1147
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Just got the EVO 3 (no plug came with it but bought some anyway) and the carb still rotates even with the lock pin tightened down. What gives? The carb needs some force to be pulled out, but when at opt temperature wont it just vibrate out of place?
HarKonnenD is offline
Old 02-03-2008, 05:29 PM
  #1148
You have to grind a little off of the face of one of the 2 pieces that make the pinch bolt. Some of the them seem to be a little long and they hit each other before pinching the carb.
I guess I've been lucky, 3 engines (1 evo2 and 2 evo3) and havent had this problem.
Old 02-03-2008, 06:05 PM
  #1149
Originally Posted by mrgsr
Hi all
Picco 2607 is no doubt the best combination with the motor. After running with the nov 2630 at first, the power difference was very noticeable when I put on the 2607.
pelico is offline
Old 02-03-2008, 06:33 PM
  #1150
Hi all
John,
If you read most of the post in this thread, there is only 1 pipe that gives the most power out of the JL's/PICCO certainly it won't be the 2630.
Old 02-03-2008, 08:32 PM
  #1151
HarKonnenD's Avatar
Ty nitro dude gonna go give it a try.
Old 02-03-2008, 08:38 PM
  #1152
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
Hope you bought picco plugs cause nova's dont fit.
Serpent-Dan is offline
Old 02-04-2008, 06:41 AM
  #1153
rcrevolution's Avatar
wow HarKonnenD, my JL3 has no problems...
I put the carb on tightend the screw down and the carb is on there like its welded on.
yes it didnt come with a plug, but didnt team kamekazi's comewith one because he included it? the JLR never came with one either.
rcrevolution is offline
Old 02-04-2008, 05:56 PM
  #1154
HarKonnenD's Avatar
Folks RCREVO and I have joined the EVO3 club... I was impressed with the regular EVO2 top end and snappier bottom end so if the 3 had to be better for the price we car pooled to our LHS to get it. Yes I did pick up plugs for it and went with the #6 plug. Too bad I found a fault clutch bearing which I will go to the LHS for again sometime this week.
I do notice the motor seems slightly smaller and feels lighter than the OS engine as well. Yes the heatsink size is a big give away too. There seems to be a little play in the crankshaft where I can pull it forward slightly...VERY slightly though. Should I return it?
Old 02-04-2008, 06:18 PM
  #1155
Im no expert, but if you're able to move the crankshaft while the clutch is on the engine, then you clutch nut needs to be tighter.
Just make sure you tune the bottom end rich, and run for at least 2 minutes before you tune it, they get better after they warm up.
I dont know what kind of break in you will use. We break them in with one tank at idle and then 5 tanks at a very rich full throtle, so rich the wheels dont move. Thats per Team Kamikaze instructions.
I was cleaning my newest engine on Sunday (it has 3 club races on it) and I can still feel metal to metal when I spin the engine.
