JL Racing .12
#2086
Today we run 16% and 25% fuel. If you run 16% then just run the engine as it is. If you run 25% then you might need to add a shims.
Those shims are between innerhead and sleeve. You have it explaned very good here: IELASITUNED Engine settings by Daniele Ielasi - YouTube
The shim that you put under the sleeve changes the character of the engine.
