Kyosho V-ONE RRR Evo
#2971
personally i'll try 80000.
#2972
I am sponsored by XS that provides IDM to me and I haven't really been through the trouble because it's the same clutch with various shoes/springs. I may have to order one with all this talk though but I'm sure his stuff is more concentrated to long ribbon tracks and probably 8th scale.
Just like Twister is better than ATS to me because I have the privilege to run their tires even though it's the same rubber, same process, same wheel just shipped to america in a different box.
#2973
TMG4RS
#2976
The sirio clutch is the main reason why I do poorly in the early qualifiers at night at one of our local tracks, the track is just insanely slippery and I would rather just wait until the main when the traction comes up and take home the win and let someone else have tq or else I would have to make adjustments every run and who wants that for club racing.
#2977
you guys and your clutches i run the stock 3d clutch and it works just fine i am sure the sirio clutch may be better but i am not going to change a good thing on my car and the sirio clutch is not made by capricorn
#2979
Correct, which is why I recommended the 2d kyosho clutch that the evo 2 will be coming with. I like the Sirio don't get me wrong, but you have to know spring compression, gap and end play extremely well before you can even bother switching to any clutch for more performance.
The capricorn Clutch disk,shoe,Bell are smaller
Im not pushing the envelope on the Sirio because of any sponsorship just based off of experience of using it. If anyone had the choice to go with the 2d or Sirio they are equal in performance so any choice won't be wrong
I ran the 3d then 2d then Capricorn then sirio at times I will use the 2D in practice but in Qualifying I use the Sirio on my Qualifying motor & mains
#2981
Does anyone know or have setups for RRR. to use at the GLC and Fortmyre?
hit me back here or pm me. Thank you
#2982
#2983
i race with chris on a regular bassis and let me tell you he likes a loose car i tried his setup before for kissimmee and it was ok just loose and lots of steering. its hard to run others setup because everybody drives different
#2985
