Kyosho V-ONE RRR Evo
#3001
Hey guys, Im having trouble with my 2nd gear stripping. Just wanted to know how you guys set your gear mesh. Do you guys set it to move completely free? Or a little tight in such case that you can hear a noise coming from the gears? Can someone post a pic of how close they set their gear please? Im really frustrated with this issue...
#3004
I always attach the engine to the engine mount using loctite. Then I just adjust the mesh using my eyes and fingers. I try to set the mesh as tight as I can without the gears being too tight and making funny sounds. Be careful when you tighten down the screws that attach the engine mount to the chassis as sometimes the mount will shift slightly as you crank down on them. I really start by snugging down the first one, then the next and so on. Then tighten them. Recheck the mesh once the screws are tight.
I also use flathead screws with washers and I never use loctite on them. I have no problems at all with stripping gears.
#3005
I don't worry about noise of gears indicating that is tight, but I don't let it too much tight
but you should consider check for play at clutch and gearbox bearings. Another point, do not let to much gap between 2nd clutch shoe and spur gear. It cause a abrupt shifting and can contribute to gears stripping
if you can use high quality bearings (high speed) at gearbox system its helps
what screws are you talking about?
try to use a soft paper. that paper to clean the ass is a good idea how do I say this in english?
#3006
#3007
Also Something I ran across this past weekend, Make sure your rear belt is not too tight..I made a diff change and had the belt too tight , and started stripping 2nd gear as soon as I got back on the track.2 of them in a row Never stipped a gear before in this car. I loosened up the rear belt and , Wala.. No more stripping gears. Just a helpful tip i found. hope this helps
#3008
#3009
Thanks for the help guys... The bearings on the clutch bell are not even 1 race old. And I dont think it is the oneway bearing because I have more than 1 and changed it ocassionally and stripping still occurs. I just checked the rear belt and its not that tight, gonna try to loosen it a bit more.
The screws im talking about are the ones that go below the chassis and hold onto the engine mount. I used to have the 2.5mm hex screws that hold the rear anti-roll bar and never had one single problem with tighten it down. That was until from use, the screws lost their heads and had to dremel them down. I switched to what Scott Fisher uses, flat head hex screws with washers...
Anyone else runs their car with a bit of noise meaning that their gears are a little tight without any problems?
I'll probably get the aluminum brace that goes over the engine to see if that helps.
#3010
When I first got my RRR I had the same problem, couldnt go a tank without striping second gear. I sourced it to the big bearing on the clutch bell. It seems that the bearings that come with the clutch are crappy and they have a lot of play. I tried a 3 year old bearing that I had sitting around, and the 2nd gear striping problems are done. I've only strip maybe 3 gears in 1 year.
#3011
I was plagued with stripped gears during last years FORGASS season. I would go thru anywhere from 3 to 6 gears in a 2 day race week-end. Very Fustrating - especially when you have tried everything!
The lasted thing I tried was meshing the gears very tight. As soon as it loosen up a bit, I remeshed them tight again. It is a bit noisy but it seems to work . . . for now
#3012
