Kyosho V-ONE RRR Evo >
Old 07-15-2008, 10:02 AM
  #2986
GSPOT's Avatar
Trader Rating: 62 (100%+)
THATS WHAT IT LOOKED LIKE!
GSPOT is offline
Old 07-16-2008, 05:40 PM
  #2987
Replacing my stock clutch spring and going with the orion spring. Does anyone have settings they would recommend for the EVO car?
Thanks,
Brad
bradley70 is offline
Old 07-16-2008, 06:20 PM
  #2988
huskerfreak's Avatar
Few questions where are you guys getting this Sirio clutch or pics of it I am just interested about checking out.
Also where are you getting info on the release date for the evo2 in the US as Kyoshoamerica has nothing abut the car on there site. The main site shows the car already released. Anyone have any concrete non hear say answers on when.
huskerfreak is offline
Old 07-16-2008, 06:40 PM
  #2989
Trader Rating: 28 (100%+)
I got my sirio power clutch directly from Kyosho America. My information regarding the date for the Evo 2 comes from the Kyosho team manager.
Scott Fisher is offline
Old 07-17-2008, 07:28 PM
  #2990
Thanks,
Brad
Anyone?
Old 07-18-2008, 07:59 PM
  #2991
Riketsu's Avatar
Trader Rating: 34 (100%+)
Im using the orion spring... Still using the same gap... .5mm for my SCT
As for the clutch tension... i tighten it until I see two threads on the nut... Then I use that as a starting point and test the car on the ground.
Riketsu is offline
Old 07-21-2008, 12:08 AM
  #2992
RC MARKET's Avatar
Kyosho V Onew RRR Evo. 2 was released !!
Attached Thumbnails Kyosho V-ONE RRR Evo-ky-31262.jpg   Kyosho V-ONE RRR Evo-ky-31262a.jpg
RC MARKET is offline
Old 07-21-2008, 02:33 AM
  #2993
barg's Avatar
Ive started building already. Check out the Evo 2 thread.
barg is offline
Old 07-21-2008, 04:42 PM
  #2994
Riketsu's Avatar
Hey guys... www.kyosho.com says that the new Evo 2 comes with the M3 2-speed system. Can I buy it from the M3 and fit it onto my Evo? Or are the spur gears different or does something that wont make it fit change?
Riketsu is offline
Old 07-21-2008, 05:12 PM
  #2995
impalabob64's Avatar
Default 2speed
It comes with the 2speed shoes from the M3, an the ring on the inside of the second gear spur has the steel ring now instead of the aluminium.The shoes you can buy from Kyosho,they have the new spur gears in stock.With the steel ring.
impalabob64 is offline
Old 07-21-2008, 06:40 PM
  #2996
Originally Posted by GMartinez
The IDM clutch is made by Capricorn Myself & another team mate tested the Capricorn clutch & we both had issues there nothing out there that performs like the Sirio power clutch the @d is as close to it & settings are Identical gap,spring tension,endplay
The clutch bell and the flywheel are the same made by Capricorn. The differences are the clutch spring and also that you get different pieces in the clutch kit. That is all as Sam said Capricorn is making the pieces. Daniele has put the clutch together with what he uses in the races that he attends. So I can not see how you did not have good luck with the Sirio and no luck with the Capricorn. You did not test the IDM clutch did you. If you did what set up did you use? And if you did not have good luck there have been differences in the clutch material from one brand name to another. Maybe this was the case.
xspower is offline
Old 07-21-2008, 07:30 PM
  #2997
GMartinez's Avatar
Trader Rating: 91 (100%+)
Flyweights was the issue Jerry on the capricorn clutch no issues with the Sirio.
I sent a message to capricorn back in December & they replaced the defective parts I still have the Capricorn Clutch I just don't use it since no other shoes work with it
GMartinez is offline
Old 07-21-2008, 08:44 PM
  #2998
GMartinez's Avatar
Bobby the new gears have a different ending Item letter VZ114-55C,.VZ114-56C which are not in stock yet same number it just went from B to C due in August fom the U.S. same release date for the Kit
Old 07-28-2008, 04:19 AM
  #2999
GEO
GEO's Avatar
Could someone help me.. Where can we find kawahara parts..??
Just give me a link
Ôhanks..
Nick
GEO is offline
Old 07-28-2008, 08:32 PM
  #3000
Riketsu's Avatar
Hey guys, Im having trouble with my 2nd gear stripping. Just wanted to know how you guys set your gear mesh. Do you guys set it to move completely free? Or a little tight in such case that you can hear a noise coming from the gears? Can someone post a pic of how close they set their gear please? Im really frustrated with this issue...
Riketsu is offline
