Tamiya TRF416 / TRF416WE / TRF416X
#7682
Hi guys,
I have a GTB 3.5 system that I installed in the car. Novak recommends a final drive ratio of 10+. Right now the smallest pinion I have for the 105T is a 26T which puts me at 8.5.
I do have a 112T 0.4 spur (from TA04 / TRF414) and was wondering if any one has tried it and if it will fit?
#7685
spurs for 17.5
Hi, I'm a off road guy about to jump into onroad, and I want to start off with the best kit, 416x.
I know nothing about roll-out, but Im going to start racing stock, which is 17.5 where I will be racing.
I need to know a few things before I place my order, as where I live I cannot get to a hobby shop, and do most of my ordering online.
What size spurs do I need?
What size pinions do I need?
48p or 64p?
sorry for the noob questions.
any help would be greatly appreciated, so I can order all in one hit.
48p or 64p?
#7686
48p or 64p?
48p or 64p?
#7689
Are you going to run rubber or foam? Carpet or asphalt? Which speed control will you be running? Inside on carpet most run 64p, something like 94 to 100 in increments of 2 for the spurs and anywhere from 38 to 50 for pinions, but that really depends on the size of the track, and you can probably narrow that range down. If you already have 48p from your offroad stuff that will work just as good, just not as fine FDR available. Give us some more info and we can narrow it down for you more.
and the 416 has an internal ratio of 2.055 from what I looked up.
so is there anything preventing me from using a 48p, 60t spur and 35t pinion?
I know with my offroad car I cannot use 60/35 because my motor will hit the gearbox.
and you guys use kimbrough or robinson spurs with a 3/8" hole ? I have some from my offroad.
#7691
#7692
Originally Posted by captain stacker;
did bit of research, apparently at that track guys are running from 3.3-3.5 for 17.5 stock.
cause with the new ones ppl are running 4.5 or lower
I run a tekin and I'm currently running 4.7 but with the new
sw that may go into the 5s
So go to your local track and have a look and talk to the
guys running stock most will tell ya wait there running
#7693
It will depend on what speedi you are planning on running
4.5 sounds better, im running team wave, most likely a tekin by the end of the month.
Thanks for your suggestion.
I will start around 5, and work from there.
#7694
Ya my mate is running a teamwave and
he is around the 3.9-4.6 mark but the
3.9 is with the x12 lrp
Happy shopping
But have a look at grarchart.com
as it will give you a good idea were to start
Happy shopping
#7695
hey all!
Can i use the tamiya 51344 rear belt on a 416we?
i didn't fint how many tooth it has and the we
are they the same?
are they the same?
