Tamiya TRF416 / TRF416WE / TRF416X
#8432
Thanks CraigM!
#8433
Pardon my ignorance as I don't know where to find ackerman.
I do appreciate your response. I should have realized that the ball connectors used as kingpins could be used. I'm very excited about this new chassis, and I'm afraid my enthusiasm is getting ahead of me.
Thanks CraigM!
Thanks CraigM!
#8435
Evening all... just a quick post to show the first version of my LiPo chassis.
There's a few issues on this prototype, cells are a too far back, and get a bit too close to the right rear bulkhead, and I need to modify the screw hole countersinking a bit as well... but overall happy with the result so far
And yes... its not very wide!
#8436
#8437
Something to ponder though, how many current generation batteries still have the round bumps on the bottom? All the current ones i can think of have eliminated the bumps as the size has gotten larger.
#8438
I'm in the process of building my 416X and I have a few questions:
- Do you guys recommend using Loctite on the screws that thread into the bulkheads and motor mount?
- Is there an option part for the long blue alloy ball connectors? Part #? I fear the longer ball connectors may break or bend.
I still have the suspension to complete, but much of it seems to be a lot like my TA05 IFS-R.
Thanks!
Thanks!
I never had a problem with the ball connectors, but you can switch to the optional steel ones.
The IFS-R is using the 416 suspension system. You can swap them back and forth if needed.
The turnbuckles hold up for the most part, but I highly recommend getting Ti ones for the long steering rods. The alum ones bend like butter. Other than that, I would carry lots of front knuckles, Chubs, and spool cups.
#8439
#8440
Gave the Smokem chassis and steering brace a good shakedown on the weekend. Managed to qualify second. Had a crappy 1st final finishing 4th. Made a few adjustments for the 2nd final and managed to stay 2nd while setting fastest lap. Then took out the 3rd final and again set fastest lap.
I lacked the top speed of the others as I was still running the old SP software and yet to find the sweetspot for my new SP V3 motor (10.5). Hope to find some more speed with some more tuning and the new SP software!
#8441
hi guys,
has anybody tried the new exotek chassis yet? if yes, can you give any impressions on the performance? also i would be interested which kind of lipos the exotek chassis actually can fit or not. i am driving LRP 5300 40C mainly but was thinking of buying the new LRP's 5900 50C shortly. but since they are bigger in size i am wondering if they still fit the exotek chassis. any hints on this??? thx
#8442
haha, nice to see you here. I just want that chassis plate...
Here's a good cheap alternative;
You can get 'em here http://www.r2hobbies.com/products.ph...8&cat=190&pg=7
#8443
hi guys,
I just installed an exotek chassis on saturday and did a practice run with it yesterday. The car was very well balance and handled great. Unfortunately, some dude parked his car in the middle of the straight and of course I hit him at full speed and broke the suspension so I haven't raced it yet though. Initial impressions were very positive. I can say in terms of batteries that the thunder power 5200 fit perfectly. There's not a lot of front to rear play. There's about 1 mm of space left between the top of the battery and upper deck. I have the battery brace/weights in the middle hole of my chassis. If you're using the carbon straps then you will probably use the outer holes in which case the upper deck probably won't be an issue. But if your battery dimensions match the Thunder, you'll be fine
#8444
How about the chassis flex? Is it good enough? Hope to hear more from you about the chassis performance.
#8445
LOL! It's not "UK Graphite"! It's called 2x2 twill and it's used all over the world. Mostly used as the decorative outer layer on automotive parts. Looks silly on RC cars because the weaves are way too large and spaced out...
