Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 09-20-2016, 05:35 AM
  #3301
Default Gull Arms v Flat Arms.
Guys,
Sure this has been covered, but cannot find it, but what does putting the gull arms v flat arms do to the car?
Thanks for pointers
lee.willows is offline
Old 09-20-2016, 06:03 AM
  #3302
Mason's Avatar
It has, in the first post.
Gull-wing front arms with wider shock tower: lower CG and increased on-power steering
Flat front arms with narrower shock tower: more responsive steering and quicker release out of corner
Mason is offline
Old 09-20-2016, 06:14 AM
  #3303
Trader Rating: 13 (100%+)
Anyone know of a good laydown setup for medium grip indoor clay track?
Thanks!
Sean B. is offline
Old 09-20-2016, 06:20 AM
  #3304
Mason's Avatar
First post..
here's one of a few sites to answer that question
http://site.petitrc.com/setup/associ...tedRC10B6.html
Mason is offline
Old 09-20-2016, 06:27 PM
  #3305
Trader Rating: 515 (100%+)
Thanks!
I'm not sure the laydown is your best bet for medium grip. I. myself, like the b6d better when there's not a lot of traction. Since that doesn't answer your question I'll tell you what others at our track have done. (1) you can swap to the flat arm front, run softer springs, and add droop or (2) one guy runs the B6 close to box stock but with white/white springs and that seems to work for him. I'm not sure what minor changes he made but he did something with the rear link height.
QDRHRSE is offline
Old 09-20-2016, 07:49 PM
  #3306
Anyone know the weight difference from the regular stock body and the light weight version from team associated?
M2126 is offline
Old 09-20-2016, 08:02 PM
  #3307
Kegman21's Avatar
I love reading all the updates every week. Keep it up guys.
Kegman21 is offline
Old 09-20-2016, 08:15 PM
  #3308
Woulvesbaine's Avatar
Trader Rating: 12 (100%+)
Most people are running low profile servos in this car that I can see. I was thinking of trying the Xpert 3000 Series High Speed Low Pro servo in it. Has anyone tried this servo in the car?
https://www.amainhobbies.com/xpert-3...i-3402/p448663
Woulvesbaine is offline
Old 09-20-2016, 09:02 PM
  #3309
Allen Drebi's Avatar
Trader Rating: 18 (100%+)
Try this. Very smooth reliable and faster. I have it in two of my cars and no issues
https://www.amainhobbies.com/protek-rc-160ss-low-profile-super-speed-metal-gear-servo-high-voltage-metal-case-ptk-160ss/p273487
Allen Drebi is offline
Old 09-20-2016, 09:05 PM
  #3310
Why do I see so many b6s and b6ds with titanium screws. Do they make that much of a difference?
Ericc is offline
Old 09-20-2016, 09:34 PM
  #3311
Tech Prophet
Wildcat1971's Avatar
Trader Rating: 84 (100%+)
I have them because they dont rust and are shiny, lol
Wildcat1971 is offline
  #3312
Tech Prophet
I have one. It developed the shakes.
Old 09-20-2016, 10:22 PM
  #3313
tsair's Avatar
Dumb question, but what size wrench do you need for the turnbuckles? I always thought they were 3.5mm, but are they actually 3.2mm (1/8")?
tsair is offline
Old 09-20-2016, 10:46 PM
  #3314
Trader Rating: 43 (100%+)
depending on how hard core you are in racing your buggy.
Phillip F is offline
Old 09-20-2016, 11:06 PM
  #3315
I just measured this on Sunday, 3.2mm is correct for the b6d.
Brian Bosley is offline
