Team Associated B6 & B6D thread
#3751
#3752
#3753
speaking of servo horns...whats the correct alignment when fitting? i only have experience with the TLR22 which needed to be slightly left
#3755
WOW this page looks like the font of all knowledge for the B6
Im over in good old England, just upgraded from a fully tricked up B5m to a B6 for our winter indoor carpet racing season
loving the car and very impressed with the overall build quality and how well it seems to be thought out
#3756
so far I am liking it from what I am seeing, I need to still give mine the good ol full teardown and rebuild since its used (however, looks very good) but happy so far.
Mine came with those Kashima or whatever they are called shocks and the stock bodies still, anyone point keeping the stock bodies around (like say, certain, conditions, etc)?
#3757
Tech Prophet
#3758
Super Moderator
Trader Rating: 31 (100%+)
#3760
Ok so I got the lunsford motor screws for my laydown. The only thing is that the driver rubs against the side rail when I try to screw the bottom screw. Anyone else have this issue? I guess it's because the lunsford screws have a 2.5mm hex. And I guess the only fix is to dremmel down a bit of the side rail.
#3761
Anyone using the anti roll bars? Suggestions on which to use for carpet? There's 3 different ones for the front and rear. Thank you.
EDIT: NVM. I see it really depends on the track itself.
#3762
Started to build my B6 today and now when i started to build the
diff the manuals says "Add a drop of Diff Lube (#6591)" i have looked in the box but cant find it?
Should it be included in the kit? Or can i use the included Black Grease instead or some other grease?
#3763
In the B6D kit, the clear diff lube should be included in a small tube the same size as the one for the black grease. I expect that the B6 kit with the gear diff may not come with the diff lube. If it is just calling for the drop of diff lube for the transmission gears the black grease will be okay.
#3764
#3765
The internal diff gears will be lubricated by the diff oil, and yes you can still lubricate the outer gear of the diff (with a dab of grease, or if you get the diff lube).
