Hot Bodies TCX
#1607
Unfortunately, as you said new 39T could not worth due larger pitch, so i said before "larger belt in front", just because i think just put 39T gear diff of 3racing could help little with small adjustment in bearing holder even is different pitch, to keeping original pulley in the rear, but you said is not enough and worth, is too tight.
Anyway, thanks from your help!
#1608
Could Somebody confirm if is possible using 3racing's bones and roller joints, please?
Best regards
#1609
In fact i have TCX now but not starting building yet, i want using gear diff in front, so i decided now, after chatting with you, using 38T pulley gear diff in front and original diff cup with 38T pulley of Sakura in rear.
#1612
Anyone know if these will fit the TCX? Any mods necessary?
http://os.3racing.hk/products.php?products_key=4963
#1613
#1615
#1616
the pin is not as big as on the HB driveshaft........
if you have some broke HB shafts, push the pin through, then get your tamiya, 3 racing or what ever 46mm steel shafts, push the pin through, and re-drill the shaft for the correct size pin.
#1617
#1618
Best regards and Merry X'mas
#1620
You know, as I am building my TCX now, i am finding it annoying that the "standard" kit setup doesn't contain the parts that the pros are using as their "base" setup. So not only is the kit $460ish, but now we will need to cough up more money for additional items no matter how small (for ex- 40w shock oil, 3 hole pistons, springs, and they don't even include cheap allen wrenches)
