Hot Bodies TCX
#2357
#2359
can anyone tell me difference of atomic gear diff and spec r gear diff?
#2361
Trader Rating: 102 (100%+)
perfect fit
for me the High Traction arms were a perfect fit.
from what I measured, everything lined up perfect.
there is about. .05mm more plastic where the Chub drops in, just took out a shim I had there...but no modification needed.
I only changed the front arms but rears measured accurately also.
before I broke at least twice a day...changed to this haven't broke one. They can take a some abuse.
#2362
1.5 block in the front
2.5 block in the rear.
1.5 mm shim under all pivot blocks.
front
.75 toe out
outer camber link 1mm shim
inner camber link 2mm
1mm bump steer shim.
top #2 shock position (from inside)
lower outer shock position
wheelbase from outer front has 1.5mm
ride height = 5mm
droop = 2mm over ride height
Rear
outer camber link 0 shims
top #3 shock position(from inside)-
wheelbase from inner rear has 1.5mm
ride height = 5.25mm
droop = 2.5mm over ride height
shock oil = 40 front / 35 rear
springs = HPI pink dot in front/ HPI silver dot in rear
no sway bars
gotta play with the springs.
if car pushes slightly play with the rear pivot block shims.
can't hurt to try.
It's been working for me quite well.
#2367
I have been using 44mm. 46mm driveshafts might get stuck in the outdrives.
Greets
Greets
#2369
