BMI's DB12R
Old 08-28-2007, 07:46 PM
  #916
Andrew..
you will really like the car.. just take you time building the front end
The car is 99.9% tweak free.. the other 0.1% is caused by my bad building skill.
~Ming
aoizip is offline
Old 08-28-2007, 08:22 PM
  #917
Mr. McGoo's Avatar
Trader Rating: 23 (100%+)
got to check out one today - it wasn't on the track - just freshly built. from a pit point of view - its a work of art - i really liked how everything flowed together.....
tempting.....
Mr. McGoo is offline
Old 08-28-2007, 08:59 PM
  #918
theisgroup's Avatar
jason,
ygpm
theisgroup is offline
Old 08-28-2007, 11:06 PM
  #919
Originally Posted by Nova F1 Racer
The rear axle, mine is a little tight and I'm going to smooth the axle out with 2000 grit autobody sandpaper.. It goes it tight on the bearings and it needs to be a good fit but not too tight...
Make sure the side damper are install so the opening is on top and not next to the rear wheels....
I found my rear axle was tight in the bearings in the kit, too - but not in other bearings I have in my box. Check with your other bearings before you sand the axle and find it is too small for your other bearings!!
Side-damper tip is a good one, thanks!! Apart from that, it is the best kit I have ever built.
SlowerOne is offline
Old 08-29-2007, 04:56 AM
  #920
Nova F1 Racer's Avatar
Originally Posted by Vicko
so when well the second production of cars be ready to sell?
Jason, charge this guy double!!
He's already fast with a 12 scale.... Vicko, didja see Casey run my car last week? He fine-tuned it and wow... What a difference.... I'll be at the Track tonight for ir maiden run on carpet... Please have pity on me....
Nova F1 Racer is offline
Old 08-29-2007, 04:58 AM
  #921
I totally agree with this kit being put together real nice... I'll check the bearings before I sand the axle.. Thanks for the tip...
Old 08-29-2007, 05:18 AM
  #922
protc3's Avatar
Trader Rating: 13 (100%+)
hey guys,
the bearings used in the kit are high quality bearings and the tolerances are real close on the i.d. and o.d. to where they need to be.make sure that the ride height adjusters are seated real good and that they are not crooked in the pod.you will need to lightly file the bump where the ride height adjuster comes off the tree.that should help alot.
thanks for the kind words on the car guys.i think you will all enjoy the trouble free race time and high performance you will get from it.if you have any questions or need any help with setup,build or anything,feel free to call the shop or drop me an email.
protc3 is offline
Old 08-29-2007, 05:58 AM
  #923
Originally Posted by protc3
hey guys,
THX Jason, good point on sadning the ride height adjusters and not the shaft.... It's a lot cheaper to replace....
Man there's alot of good info/ideas/tips on this thread... I'm gonna have to burn a CD with the manuls/setups/etc for this car...
Old 08-29-2007, 06:38 AM
  #924
protc3's Avatar
no problem buddy.i usually always sand that little nub off the adjusters.i think im just anal like that. keeps everything nice and free though
protc3 is offline
Old 08-29-2007, 06:44 AM
  #925
theisgroup's Avatar
tempting.....
just get one cash master!!!
Old 08-29-2007, 07:22 AM
  #926
Now that I thought about it I started lmao in my office at work.... People walking by thought I was nuttier than usual....
Hmmm... sand a carbon fibre shaft or a piece of plastic......
But if the bearing goes on too tight then thats another issue...
Old 08-29-2007, 12:30 PM
  #927
Lost Aggresiva's Avatar
I just got done building mine too, and I can't really add much more than what's been said already. Can't wait to get it on the rug.
The only little hiccup I had was mounting the servo. My JR servo seems to be a bit small for the servo mounts. Did I do something wrong?
Lost Aggresiva is offline
Old 08-29-2007, 12:48 PM
  #928
AdrianM's Avatar
The JR servos are a very strange size. The mounts and chassis holes are desigend to fit a Futaba 9602, 9650, Airtronics 94141, 94145 or KO PDS-949 ICS. All of these bolt right up with the output shaft on the chassis centerline.
The JR3550 and Airtronics 94761 will require additional holes in the chassis and or different servo mounts. These are very undersize servos. They work great but we could not accomodate them without compromising the fit of more commonly used servos.
AdrianM is offline
Old 08-29-2007, 02:37 PM
  #929
protc3's Avatar
heres a pic of my car with the brushless gear installed.i will be replacing my spektrum cap with a receiver pack once it comes in but it will fit up right where the cap is at.its pretty clean for a guy who sucks at wiring
protc3 is offline
Old 08-29-2007, 03:01 PM
  #930
protc3's Avatar
by the way guys,i wanted to thank all of you who sent those emails about the build quality of the car.i really went above and beyond to make sure the car went together really well and that the fit and finish was really good.it is nice to see that you guys see what i am putting into this car.thanks again guys.
protc3 is offline
