BMI's DB12R
Old 08-23-2007, 06:43 PM
  #766
protc3's Avatar
his car should be getting to him next week.
protc3 is offline
Old 08-23-2007, 10:17 PM
  #767
AdrianM's Avatar
Here are some pics to go with Jason's Rear suspension description. They are from the instruction manual.
Attached Thumbnails BMI's DB12R-img_1603s.jpg   BMI's DB12R-img_1551s.jpg   BMI's DB12R-img_1554s.jpg
AdrianM is offline
Old 08-24-2007, 04:49 AM
  #768
Trader Rating: 51 (100%+)
Originally Posted by InspGadgt
I'm wondering if Apex meant more something along these lines...Most link cars have adjustable links so any inaccuracies in the manufacturing can be adjusted out in the links to keep the rear from binding. On CRC cars they have a solid link so the center pivot mount is slotted so to square up the rear pod you just loosen the 2 nuts on top of the center pivot mount, let the chassis sit flat, then tighten them down again. Is there anything like that on the DB12R or will it always come perfectly drilled? I assume the latter cuz the car just looks perfect
Yes, that's what I was trying to understand. But I understand it now. I don't think the DB12R has as much side to side roll as a spring car so the movement is probably much smaller and won't reach a binding point. It's almost like the L-bars are working like a sway bar kinda like the old Composite Craft Lynx II pan car limiting roll to make the car rotate without sacrificing side and forward bite.
Apex is offline
Old 08-24-2007, 06:30 AM
  #769
protc3's Avatar
when you get a chance to take a look,you will see there is no bind point.it will roll until it bottoms out which far exceeds the necesary travel.it works very smoothely and is more progressive than the coil springs.this is why i never did like the coil springs.all rear suspension on pan cars work with pivots,spring tension and side dampening,this is the way i found for it to work effectively with no sacrifice.there are too many flaws in other methods i have seen.
protc3 is offline
Old 08-24-2007, 06:52 AM
  #770
Agreed. I'm thinking your car is the right blend between the spring and t-bar designs. Anyhow, can't wait to take a look at it today at 301.
Apex is offline
Old 08-24-2007, 01:40 PM
  #771
EricF's Avatar
...all the carbon fiber parts are machined on the CNC machine in one shot without reclamping to ensure dead on accuracy...
will this cause alignment problems if you need to buy a new chassis or lower pod plate, since it's not bing cut at the same time? I don't think that it would since the equipment is very accurate, but I wonder
Where's the UPS guy with my kit??? Florida to Arizona can be done in 2 days right?
Janson,
can you pm me the tracing number... I'd call but my cell battery is low.
Thanks,
E
EricF is offline
Old 08-24-2007, 03:52 PM
  #772
chris moore's Avatar
Trader Rating: 96 (99%+)
Janson,
Thanks,
E
Eric are you going to run the DB12R at CH before Vegas?
Chris
chris moore is offline
Old 08-24-2007, 04:03 PM
  #773
theisgroup's Avatar
my guess is what jason is saying is that each piece is cut in one shot. so that the piece is not remove and then re-install in the machine. there is almost no way to clamp the part back into the machien in "exactly" in the same spot.
Janson,
Thanks,
E
theisgroup is offline
Old 08-24-2007, 04:38 PM
  #774
Nova F1 Racer's Avatar
I can say without any doubt that APEX now understands the car and it's unique concept of this car....
It's money....
Nova F1 Racer is offline
Old 08-24-2007, 06:49 PM
  #775
AdrianM's Avatar
Janson,
Thanks,
E
The chassis are cut on a big CNC vertical mill (see pic below). Every chassis is identical.
AdrianM is offline
Old 08-24-2007, 06:55 PM
  #776
Kropy's Avatar
I just can't get over that awesome rear pod design.
Kropy is offline
Old 08-24-2007, 07:03 PM
  #777
AdrianM's Avatar
Its pretty sweet. Jason is really big on asthetics. Anyone can design a rear pod. The trick is making it function AND look like a piece of art. He spends a lot of time making small changes to angles and curves on the chassis and alloy parts to make the complete car flow together visually.
AdrianM is offline
Old 08-24-2007, 07:22 PM
  #778
Kropy's Avatar
Has anyone weighed their car with a brushed set-up yet? Just curious
Kropy is offline
Old 08-24-2007, 07:50 PM
  #779
Mr. Shookie's Avatar
And I bet if Jason could find gun metal grey fiberglass L plates, he would have done that too just match all the rest......
-Shookie <><
Mr. Shookie is offline
Old 08-24-2007, 07:57 PM
  #780
RCSteve93's Avatar
Do you know if BMI has plans to make caster blocks in aluminum anodized the same color as the rest of the car? I want to know before I buy the CRC ones, so I can wait.
RCSteve93 is offline
