Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 09-03-2009, 02:06 AM
  #751
oh yeah........the angle of the top arm is increased which will effect your camber so you might want to change your inboard camber setting to counter this if you dont like it.
junn is offline
Old 09-03-2009, 02:29 AM
  #752
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Originally Posted by junn
My next tuning option is to try the TRG rubbers as thats what everyone uses in our club, apparently theyre the tyres to use, I can keep up with an F103 running TRGs with Zen 25s on my F104
I've got a set of the TRG wheels, and the inside diameter of the wheel is virtually the same as the length of the kingpin, so no amount of washers will really help
Is there another wheel the TRG tires will fit on? I'd really, really like to try them
PDR is offline
Old 09-03-2009, 02:33 AM
  #753
bugga.....i was hoping to try those too, well might have to stick to foams until TRG or someone make some rims and tyres to suit
junn is offline
Old 09-03-2009, 02:35 AM
  #754
I dont suppose the wheels of the F103LM will work? they were released with tamiya rubbers, or are they the same size as the TRG's?
junn is offline
Old 09-03-2009, 02:37 AM
  #755
veecee's Avatar
Trader Rating: 34 (100%+)
Hey junn, thanks for posting. Is the rear still wider than the front?
Looks like Zen has some donuts for the F104 now. There's a 40 front and a long-life less grippy unknown compound. There's also a 25 and 30 rear. Would be interesting to give some of those a go...
http://www.rc-zen.com/F104ringtyre.html
veecee is offline
Old 09-03-2009, 02:38 AM
  #756
alan1467's Avatar
can you not fit the washer above the wishbone so it does not alter the camber but still lift the kingpin?
alan1467 is offline
Old 09-03-2009, 02:48 AM
  #757
Not a problem, ive been a member of this forum for 5 years and ive finally been able to contribute something
thats a good idea too putting the spacer under the top clip.
I got prices from RC champ for those Zen tyres but one of the guys in the club gave me the Zen/F103 tyres to try as I was having a horrible time keeping the car from swapping ends. Im not sure what it would be like with F104/Zen rear tyres as opposed to the wide F103, theres no substitute for contact area
The back is definately wider than the front it measures 200mm across the rear tyres and 178mm across the front
junn is offline
Old 09-03-2009, 02:51 AM
  #758
Hmmmm could lathe of the difference?
junn is offline
Old 09-03-2009, 02:52 AM
  #759
alan1467's Avatar
I have them some days
alan1467 is offline
Old 09-03-2009, 03:04 AM
  #760
veecee's Avatar
Thanks for the measurements too.
veecee is offline
Old 09-03-2009, 04:35 AM
  #761
Andysan's Avatar
Hi,
I have got my old F102 out to run against the F104s. I've bought some premounted wheels and tyres by Zen RC from RCMart but they are one piece. The F102/3 wheels are two piece with the thrust bearing inside. Anyone know what i do with the thrust bearing please?
Andysan is offline
Old 09-03-2009, 08:46 AM
  #762
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
I'm thinking of making some new front spindles that would push the wheel out further, so the TRG wheel will clear the kingpin. Does anyone have an F104 and a TRG front wheel that could tell me how far the wheel would have to be pushed out to clear the kingpin? Based on the measurements given before, I could push each wheel 11mm and still have the front wheels be the same track width as the rear using rear TRG rubber tires.
Steve
SRBMOJO is offline
Old 09-03-2009, 10:19 AM
  #763
robk's Avatar
Trader Rating: 22 (100%+)
The tech car looks to have the same hole pattern for the front end as Tamiya. The front end from the 125 would probably be the correct width if you're gonna run F103 tires.
robk is offline
Old 09-03-2009, 11:11 AM
  #764
Trader Rating: 28 (100%+)
Originally Posted by Andysan
Hi,
Just pull the thrust bearing out of your Tamiya wheels and slide them into the Zen wheel (the wheel inner diameter allows this)
madjack is offline
Old 09-03-2009, 11:52 AM
  #765
SRBMOJO's Avatar
Any link to that part?
SRBMOJO is offline
