Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 09-03-2009, 05:59 PM
  #766
Andysan's Avatar
Originally Posted by madjack
Just pull the thrust bearing out of your Tamiya wheels and slide them into the Zen wheel (the wheel inner diameter allows this)
Thanks madjack, a short while after i posted i figured out that i could do this and felt like a bit of a tool. I came backto see if anyone had replied though because i wasnt sure that this would run OK, but after reading your post i tried it and it seems to be OK.
Thanks again!
Andysan is offline
Old 09-04-2009, 08:21 AM
  #767
InZane's Avatar
I've had time to do some more extensive testing now and the F104 is super dialed!
The rear is made softer back&forth due to some modifications of the T-bar and the pivot pod (I'll post pics and a setup sheet).
the car is totaly planted with kit tires without tire additives. Next week I will try a 8.5 Xcelorin - hopefully I can post a video as well.
InZane is offline
Old 09-04-2009, 02:17 PM
  #768
RonF's Avatar
Default Silly question
But does the F201 tires fit on the F104 rims? Im mostly looking at them for display, not running.
It would be nice if Tamiya would make some to fit the F104s and 103s....
RonF is offline
Old 09-04-2009, 03:38 PM
  #769
veecee's Avatar
Trader Rating: 34 (100%+)
F104 are foam rims - smooth with no ridges for mounting rubber. So that's a no.
veecee is offline
Old 09-04-2009, 03:39 PM
  #770
veecee's Avatar
Awesome work Inzane. Looking forward to it. So is my dremel!
veecee is offline
Old 09-04-2009, 04:06 PM
  #771
RonF's Avatar
And I also assume that the 201 rims wont fit F103/4 series cars either?
RonF is offline
Old 09-04-2009, 04:09 PM
  #772
veecee's Avatar
F201 rims have hexes front and rear. So the fronts would be the problem.
veecee is offline
Old 09-04-2009, 07:42 PM
  #773
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Default TRG wheel dimensions
Hopefully this will help someone. If not, let me know what measurements you need
Ooops - and dimensions are mm.
PDR is offline
Old 09-04-2009, 09:06 PM
  #774
gtypecanare's Avatar
Glamor shots from last weekend.
gtypecanare is offline
Old 09-04-2009, 09:13 PM
  #775
hmmm.... understeer problems....
Old 09-04-2009, 09:34 PM
  #776
SRBMOJO's Avatar
Trader Rating: 67 (100%+)
King pin measures 33.4mm, you would have to shim the steering arm perfextly in the center of the kingpin to have it work, leaving no adjustment for ride height.
Do you have the wheel and the F104 handy to see how big of a spacer you would need to move the wheel out far enough out on the spindle to clear the kingpin?
I ordered a complete set of TRG wheels/tires today from RC Mart, I don't expect to have them for a week or so. I am determined to make this work somehow.
Steve
SRBMOJO is offline
Old 09-04-2009, 09:40 PM
  #777
Arahawak's Avatar
Trader Rating: 32 (100%+)
Nice photos.. the front left are lifting!!
Arahawak is offline
Old 09-04-2009, 10:50 PM
  #778
PDR
PDR's Avatar
Looks like you need around 6mm to push it out far enough to clear the kingpin and the c-clip. Unfortunately, this means the axle is too short for the bearings (particularly the outer one) to ride on.
Longer front axle, anyone?
Phil.
PDR is offline
Old 09-04-2009, 10:58 PM
  #779
SRBMOJO's Avatar
Phil.
Yeah, that is what I was thinking. When my tires get here I'm on it.
What is the diameter difference between the TRG rubber tire and the foam F104 tire?
Steve
SRBMOJO is offline
Old 09-04-2009, 11:22 PM
  #780
PDR
PDR's Avatar
Outer diameter of the TRG rubber front is about 56mm. Somewhat less than the 59mm foams on there at the moment (done a day's racing), but more than the well worn set of foams.
PDR is offline
