Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 08-26-2009, 02:52 AM
  #721
veecee's Avatar
Trader Rating: 34 (100%+)
From the Aussie forum...
Originally Posted by DTM.inc
For all the F104 lovers out there, I thought I'd share this set up sheet.
It's basically what you get with the kit, without Japanese text and it has editable text boxes and tick boxes.
Have Fun
If you have a good setup, please post with this PDF file.
veecee is offline
Old 08-26-2009, 07:39 AM
  #722
is there a way to save it as an jpg or something.?
-Idont have a printer,and its nicer to have it all on the computer. Then alot of papper. Its easier to share setups in computer form.
jim_ed is offline
Old 08-26-2009, 08:33 AM
  #723
InZane's Avatar
Install Cute PDF - it's freeware.
When you print your set up sheet it is saved as a non editable .pdf document on your computer.
InZane is offline
Old 08-26-2009, 12:54 PM
  #724
barneveld's Avatar
@Veecee:
Thanks for the tip!
Marcel.
barneveld is offline
Old 08-26-2009, 05:30 PM
  #725
Tommi Makkinen's Avatar
Trader Rating: 28 (89%+)
i wonder if these tires are allowed to be used in the TAC finals in Thailand?
Tommi Makkinen is offline
Old 08-31-2009, 12:04 AM
  #726
... from the Aussie forum....
would be interested in a link to this if possible please.
Cheers from accross the ditch in NZ
sijorg is offline
Old 08-31-2009, 12:36 AM
  #727
prime's Avatar
Default my Jordan
Hey guys thought i'd share my Buzzin Hornet Jordan. I did this one originally about 12 yrs ago with my old F1, so this is reliving my youth... Much better second time around.
Had its first run yesterday, Survived the run, bit of ware on the front wing though
but worse can't get it to handle, i've read the past few pages and i too am having the high speed jiggles/wobbles, one time it goes right and then left, i have done some mods to try and sort it out, i can now hold it flat down a straight, but trigger finger application must be spot on and gentle, looking forward to hearing any setups or solving of the problem. I tightened both the shock collar, and friction plate nut down, as well as changing the t plate to the Tamiya soft one... little better but not great. what is the better tyre options for the car as apposed to the standard kits
thanks
Prime.
prime is offline
Old 08-31-2009, 04:12 AM
  #728
border r/c's Avatar
whow great body!
border r/c is offline
Old 08-31-2009, 10:25 AM
  #729
RonF's Avatar
Prime,
Nice pics. The side is a little blurry, but still looks great. Ive heard B compound up front helps the 104. Perhaps the others can confirm this.
I watched the Tamiya driver run his in Marlboro McLaren colors a few weeks ago in Aliso and his was hooked from start to finish. He is supposed to have an article on setup for this car very soon. Keep checking the Tamiya USA website.
RonF is offline
Old 09-01-2009, 04:35 PM
  #730
veecee's Avatar
Great work there Prime!
There was a TCS race at Tamiya USA over the weekend and looks like there were quite a few F104s. If any of you were there, it would be great to hear from you and see your setups.
Cheers,
Vinny
veecee is offline
Old 09-01-2009, 06:51 PM
  #731
414MPH's Avatar
Cheers,
Vinny
All I can say from my observations at Alliso this weekend is... The F-104 is not yet on par with the F0103, and that was with David Jun wheeling the F-104.
Time will tell.
414MPH is offline
Old 09-01-2009, 06:57 PM
  #732
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
Time will tell.
Ok, but the 103 has only what? 15 years of development behind it, vs like 4 months for the 104. The 103 has been and will continue to be a great car, and with a little sorting, the 104 will be right there
BP SHADOW is offline
  #733
veecee's Avatar
Yeh I think that is to be expected. The chassis is still quite new, especially compared to the F103. Also the chassis is a fair bit narrower which could explain some of the nervousness people are experiencing. I think the tyres are a bit narrower too?
veecee is offline
Old 09-01-2009, 11:04 PM
  #734
Arahawak's Avatar
Trader Rating: 32 (100%+)
Time will tell.
Does somebody has David's setup ?
Arahawak is offline
Old 09-02-2009, 03:53 AM
  #735
prime's Avatar
here here....that would be sweeet to get JUNs setup. thanks to all those comments, it means a lot coming from fellow F1 fans.
prime is offline
