Like Tree2Likes
Losi XXX-S
Old 05-09-2003, 10:10 AM
  #6106
SPACEBOY's Avatar
Default tires
Has anyone used the red compound kit tires that come in the G+ kit? How well do they work? Does anyone know the specs or temp range for these tires?
SPACEBOY is offline
Old 05-09-2003, 10:18 AM
  #6107
Madcap Magician's Avatar
Yeah, the tires that come with the kit are super soft, meant for running in cold conditions. If I ran them at SRS they would blister and shred in about 2 minutes. Save them for winter.
Madcap Magician is offline
Old 05-09-2003, 10:37 AM
  #6108
tufferwilde's Avatar
Are you talking about the Kit tires for the G+ or the standard XXXS??
The tires which come with the G+ are in fact pink compound... one step harder than the reds and the tires in the standard kit are blue is memory serves correctly...
My thoughts on these tires is that they are great for use in setting steering trim... nothing more.
Wilde
tufferwilde is offline
Old 05-09-2003, 10:47 AM
  #6109
SPACEBOY's Avatar
It is the G+ kit. The dot looked red to me but it could also have been pink. I have used the low profile yellows before and had good luck with them and was just trying to see how these tires would compare. It they aren't any good then I will not even mount them up.
SPACEBOY is offline
Old 05-09-2003, 03:25 PM
  #6110
Has anyone had any problems that create a groove in the belt on the xxx-s. My car was squealing so I loosened the gear mesh and it stopped but I saw that there was a groove in the belt. Could the gear mesh have caused this?I checked an there was nothing else that could have caused it that I could tell.
P.S. Ive been driving on my asphault street and ive been having problems with small rocks getting in my fantom stock motor and locking it up and it recently started happening i don't know why. Please Help?
Brandon
Smartazz07 is offline
Old 05-09-2003, 03:34 PM
  #6111
Well, Number 1: DON'T DRIVE THE CAR ON PUBLIC STREETS!!!
You may think the drive train is sealed, but rocks and dirt can still get in through the gear cover.
Number 2: take the diff cover's off the front and rear, you may have a small rock in there that is rubbing on the belt.
Old 05-09-2003, 06:17 PM
  #6112
See
Trader Rating: 53 (100%+)
My G+ kit came with silvers.
See is offline
Old 05-10-2003, 06:00 AM
  #6113
Trader Rating: 19 (100%+)
My G+ kit came with pink compound tires.
429racer is offline
Old 05-10-2003, 07:15 AM
  #6114
Oasis's Avatar
Trader Rating: 38 (100%+)
The kit tires suck and the rims will crack in the center.If you bought a G-Plus I would think you bought it to race and not to street bash it.Use the kit rims & tires as "extras" when you sell your old car.Thats all their good for.
Oasis is offline
Old 05-10-2003, 07:54 AM
  #6115
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Anyone have trouble with the stock wheel nuts? I haven't yet but my TC3 had big thick nuts like that stock and they came off all the time. I switched to Trinity low profile and no more problem on that car. Just wondering if I should switch on the Losi before I do have a problem.
Jon Kerr is offline
Old 05-10-2003, 10:00 AM
  #6116
I was told to put them in backwards after mine flew out during a race. It never happened again. You gotta put them on tight, not like other screws where you kinda let it stop early.
AssociatedRacer is offline
Old 05-10-2003, 11:14 AM
  #6117
Do you guys know where Todd Hodge got his titanium screws that were on his car in the R/C Car issue? Where do you get a titanium turnbuckle that attaches from the servo horn to the steering rack ( Like the one on Todd Hodge's car in r/c car)?
M Ignacio is offline
Old 05-10-2003, 02:00 PM
  #6118
R/C Tech Founder
Which month of R/C Car is that article in?
futureal is offline
Old 05-10-2003, 02:35 PM
  #6119
Oasis's Avatar
I used a yokomo turnbuckle,For the ti screw kit I bought mine from my LHS(showtime hobbies)I think the brand is TRI,but I'm not sure.I do know it was not cheap($68).
Oasis is offline
Old 05-10-2003, 02:40 PM
  #6120
highwayman's Avatar
also the white ball cups he has? does anybody know who made them?
highwayman is offline
