#1471
thank you mike for your confidence in us and the information and support we provide .
#1472
www.eurorc.com has them in europe seems they are out on the 1s though
#1474
Which PDF is this refering too?
Cheers
Cheers
Just wanted to briefly say that I have just installed 518STOCK using the boost settings and gearing for 13.5 with my SP v3 motor that are suggested in HW's pdf.
Ran at two race meetings, one on a 30x16m track, one on a 20x8m track, and lacked nothing in speed or driveability to the competition, with comfortable motor temperatures.
Credit to Hobbywing for the software and documentation.
#1475
#1476
Dear Loyal customers
It has come to my attention that many of you are told that there is new software for 1/10th scale there isnt the only new software update is for 1/8th scale and if there was an update to 1/0th like the 518 and 528 you will be the first to know through email.hobbywing website and rc tech as well as redrc and many more .
Please dont ever believe that because sp has some new software out that hobbywing has to, its not the case even though Hw does do sp software it is not recommended for HW esc's for various reasons .
thank you for your time
regards Angelo
regards Angelo
#1477
#1478
regards Angelo
#1479
In use I have found that the Speedpassion 528 Software seems to run cooler on the Xtreme Stock for me on these settings at Maritime Raceway UK.
On SP 528 the minimum Start RPM is 4500 compared to 3000 on Hobbywing. This was geared at 7.13:1 overall FDR.
Just my tuppence.
Just my tuppence.
#1480
Just my tuppence.
Just my tuppence.
#1481
#1482
hobbywing
Hello, I can not update my vario hobbywing, quotes Speedpass does not work, I drive in 10.5, 1 / 12 that can come to my rescue?
#1483
12th scale esc
Hi Guys need help, running a hobbywing Xerun 120 amp 1S lipo esc on a 12th scale car
problem melting neg wire off battery (3.7 ) volt, replaced battery wires from
14g back to 12g but the esc runs very hot. using stock software 518 with the following settings .
9--6
12--7
13--5
14--5
15--5
motor is epic duo 2 10.5 on about 8 degree advance motor not hot
any help thanks
9--6
12--7
13--5
14--5
15--5
any help thanks
#1485
14g back to 12g but the esc runs very hot. using stock software 528 with the following settings .
9--6
12--7
13--5
14--5
15--5
any help thanks
9--6
12--7
13--5
14--5
15--5
any help thanks
Also you might have a slight problem with the caps as they equalise the voltage of the battery and the esc.
But from what i can its a dead short somewhere as that is excessive current flow .
