Team Associated TC6 Thread
#901
#902
? for you Keven
I know this is the wrong forum, but which speed control where you running at the Cleveland race for the 17.5 boosted class, with what software, if you know?
#904
#906
Yokomo bd-5 gear diff
top photon, apparently needs adjusting
Spec-r diff for yokomo
probably best if you went back a couple of pages as everything is detailed there.
#909
#910
his setup sheet from the indoor champs is posted http://www.teamassociated.com/pdf/ca...hamps_2010.PDF Lists him using the the SXX stock spec software 4.0
#912
TC6 Wow
Ran my 6 last night for the first time...Wow, great corner speed, very predictable drive. A couple of things that we all may have to watch for, or have already found out:
- suspension mount screws came lose on about the 5th run (I shoulda checked them)
- servo saver nut backed off (shoulda checked it too)
I'll be getting out the loctite but, so far great car!
#913
Hey guys, just getting the TC6 all buttoned up for this weekends race and have a couple of questions. I am putting Kevin Hebert's Timezone setup on the car and the setup sheet says 3* total toe for the rear. Does this equate to 1.5* per side. Also when refering to arm mount shims, the book says we should have 1mm, 1.5mm and 2mm shims. However, when measured with a calipper none of the shims are actually as thick as they are supposed to be. So on Kevin's setup if it calls for 3.5mm arm mount shims, do you think he is using what is supposed to be 3.5mm from the kit, or another shim that actually totals 3.5mm?
#915
I picked up .2 sec a lap on my first test day with it. It did help having AE team driver Lex Tyler helping me with set up(thanks for da help,you the man) the car is much better with weight transfer esp on our small track.
