Team Associated TC6 Thread >
Like Tree20Likes
Old 01-31-2011, 06:10 PM
  #1651
Buckaroo's Avatar
Originally Posted by muststopcrashin
has anyone had there wheel bearings cracking and braking down, i've just cleaned my car and found 3, just the out side ones.
I had one broken, and I thought that it was from a known hard hit on the boards that split the outer plastic hub in half as well. Got the car home and found that the other three wheels all had the outer bearing broken(no issues with the plastic, though). Outer race on all 4 was broken clean in half. VERY strange. I had new wheels on, and at least one had not ever had any hits on the boards.
Buckaroo is offline
Old 01-31-2011, 06:57 PM
  #1652
Timbulb's Avatar
You might wanna look at and follow the advice of your own forum nickname.
Timbulb is offline
Old 01-31-2011, 07:31 PM
  #1653
geeunit1014's Avatar
Trader Rating: 14 (100%+)
do you think this is the norm?
The bearings are a bit undersized on the TC5/6.. my M18 (1/18th car) uses the same 6x10 wheel hub bearings.. most other 1/10 sedans use a 5x10 bearing (ie they have bigger ball bearings, more durable). Best bet is to stock up on some avid bearings ($1/bearing), and check them every run.
geeunit1014 is offline
Old 02-01-2011, 12:41 AM
  #1654
hanzo3's Avatar
Trader Rating: 55 (100%+)
I can't find the c clip that goes on the steering post of the bellcrank. Is it like a E clip? hmm...
hanzo3 is offline
Old 02-01-2011, 02:47 AM
  #1655
Default Ballast weights
Has any one got a photo, or have seen a picture of the TC6 Ballast Weights?
Part number: 31296. I would like to see them before i order some.
Thanks, Anthony.
Handbrake is offline
Old 02-01-2011, 02:57 AM
  #1656
fantapants22's Avatar
hhah no place seems to have a pic of them
fantapants22 is offline
Old 02-01-2011, 06:21 AM
  #1657
JRXS_chris's Avatar
Same, outer rear right hub bearing cracked. Just one of them things.
JRXS_chris is offline
Old 02-01-2011, 06:32 AM
  #1658
Default SPEC-R bd5 axles in tc6
Hi!
+ YouTube Video
I use some cnc cut 10mm tool to put inside bearing more,
and now:
- outside is 5x10x3,
- inside is 5x10x4,
- hex is from yokomo: bd-011c (5mm) or nr graupner: YBD.011C,
- spec-r bd5 double joint axle
Need some work on c-hub to fit it, and I will squeeze tc6 diff, it is a little slop,
or put Y bd5 gear diff to front with 100k oil
Anyway, works, from slow rpms to high without big shaking
Also I wait very long time for ae factory to do own axle ...
tool:
M.Abramowicz is offline
Old 02-01-2011, 06:39 AM
  #1659
Castradamus's Avatar
Trader Rating: 62 (100%+)
Originally Posted by M.Abramowicz
Hi!
and now:
- inside is 5x10x4,
Nice mod!
Castradamus is offline
Old 02-01-2011, 06:44 AM
  #1660
Originally Posted by Castradamus
Nice mod!
Also I try BD5 steering blocks. They fit to c-hub, but arm is in wrong place,
to high ... Almost perfect but there is no place to put steering links
Old 02-01-2011, 08:49 AM
  #1661
Does any one know what the best body shell is for the TC6 is. On my TC5 I tried the R9 and that was the worst shell I had ever used so I changed to the DNA 2 which I also put on the TC6. The P37-R looks quite good but does it handle well or is there a better shell out there?
thanks
DomTC6 is offline
Old 02-01-2011, 08:53 AM
  #1662
Trader Rating: 23 (100%+)
2 bodies period....speed 6 (a little smoother) / LTCR (more steering)
pcar951 is offline
Old 02-01-2011, 09:52 AM
  #1663
I use the Speed 6 and it is extremely smooth through the turns... I've also heard that you may need to move the wing back a few millimeters from the middle of the mounts for increased rear handling though. I'll try it today at the track. =P
Race4Kix is offline
Old 02-01-2011, 01:01 PM
  #1664
I use the Speed 6 myself. About the best balance I have found so far from a body.
Jonesy112 is offline
Old 02-01-2011, 01:06 PM
  #1665
rc pete's Avatar
+1
rc pete is offline
