STS engines
#391
need help =(
Hi guys,
i've just recieved my D5 and went to take it apart to clean prior to break in. I had a problem. The conrod won't come out, it's not stuck or anything but the clearnce of the crankpin and crank case is not enough for me to slip the conrod off the crank pin. I've pushed the crank in as far as it will go but still i can't get the conrod off the crank. I've taken the piston liner out etc and still doens't work.
any suggestions, i know it's a stupid question but i'm a noob so it's ok
#392
STS P/S and other parts
If you are in the United States and are looking for STS parts and or motors contact Project Zen in California. [email protected] or www.projectzen.net they will direct you to your nearest dealer.
#395
Originally posted by Pit-racer
That's what Todd said also....I was just wondering.
i've tried this, and every other o'clock but still no luck =( I've tried using thread to ease it out aswell but still to no avail. Any other ideas guys?
btw, thnx for the input =D
#397
Ive not pulled my STS apart but I've done other engines, all I did was pull sleeve out so piston was slopping around then it comes off easy., almost falls off hehehe Dont know why you having problems but
#398
Originally posted by noobatron
Hi,
Hi,
1)Use a wide nylon cable tie to cross the conrod.
2)Pushed the crank to the end. (Pull in front)
3)Pull the nylon cable tie slowly and move the crankpin between 11~1 o'clock.
When you assemble them,don't forgrt to lubricate them first.
#399
Originally posted by dino.tw
Sorry,I'm late.
Sorry,I'm late.
I don't think the boss will be happy !
#400
Originally posted by EVOLUTION
Were you snoozing Dino?
#401
No lar....just too busy......my partner go to holiday lately......
I hope it's a nice holiday !
Don't feel to lonely though, otherwise you will end up like Data.
#402
Oh.......
Oh.......
DATA? WHO IS HE?.....kakaka.....can't remember.....
#403
Hope his holiday sucks and he want to back to work soon.
I read your previous post too quickly and thought you were speaking about another partner. Then when you said "he" my jaw dropped but once I worked out your coded posts I picked my jaw back up.
Does it make sense?
As for Data, yes I agree with you !
#404
Does it make sense?
Does it make sense?
#405
It seems Manti is right!
