Kyosho v-one rrr
#3391
I raced a Pro4 at last years HPI World Challenge at the Halifax track. I'd go for more rear traction to keep it stable in the sweepy turns. You'll probably have more steering than you think this way. Try 1 way in front, #11 ackerman, #2 front hinge pins. Rear, #2 hinge pins, long rear camber link, no spacer, shocks #2 hole. Stock springs 6.5mm front ride height (58mm tires), 7mm rear ride height (60mm tires). Then try 37front, 40 rear to get a bit more steering.
#3392
You will find the rear wheel camber goes positive. At the point it goes positive the wheel will break loose. To give maximum rear grip the wheel should be at 0 deg under acceleration. To ensure camber change is increased shorten the top link as much as possible and add 2 or 3mm of spacers to increase the link angle. Also drop the rear hinge pin inserts down to lower the roll centre.
Ill, show you Sunday at the track Jas
Cheers
#3393
Does anyone know if the standard RRR has been discontinued since the WC edition has been released?
#3394
#3395
#3396
Originally Posted by FW-05RR
that's odd.... I thought it was the other way around wasn't the RRR WC Edition a limited run the regular RRR should still be around unless Kyosho is releasing another touring car which I don't think will happen anytime soon
haha you know how kyosho is. they release a kit like every 2 days i swear to god. HAHAHA
#3397
Due to demand a second limited batch of WC kits were made available.
There are only 3 versions of the RRR chassis kit, the standard, the WC, and the Rubber spec.
#3398
Does anyone have Pics of how to route the servo wires to the receiver. Especially the steering servo wires. Do I route the wires between the servos and fuel tank. Also there seems to be no room for extra wire to be tucked away. Is it recommended to shorten all of the harnesses to the minimum. If someone could post pics or a diagram it would be helpful. The instructions or lack of leave me with the impression that Kyosho made everything so compact that they did not allow this into the design.
#3399
Yeah I was wondering about the WC and the standard as well because everywhere I look everybody has a WC listed and not a standard RRR. For a limited edition kit there sure are a lot of them out there. Speedtechrc is the only place I have seen a standard RRR being listed. Maybe some of you guys know of other places?
#3400
Try these hobby shops:
www.revrace.com (909) 628-9909
www.elitehobbyshop.com (626) 858-8999
They are two dealers who may have the regular kit. If they dont have them in stock (when you call), you can have them order the kit for you. It should only take a couple of days or so.
Hope this helps.
#3401
#3402
From here i took it back and turned it in under the carbon deck below the throttle arm.....from here you can either go to the receiver via the hole in the splash guard, or else route it adjacent to the fuel tank (theres room between the fuel tank & throttle servo) and then bring it in from behind the receiver.
Cheers
#3403
Oops...make that "turned the servo WIRE back towards the servo".....dang typos
#3404
Originally Posted by AndyT ©
To route the steering servo wire back to the receiver I did the following- turned the servo back towards the servo and then ran it over the top of the steering servo behind the receiver pack switch (if youre using one)...you`ll see theres a small channel where the wire can be run to do this.
Cheers
Cheers
#3405
also easier to mount servo's and route wires with top deck off car i found.
