Serpent 710
Re: Re: Re: Switch to 710
Originally posted by rcpanama
I normally go very fast the lower place I had in a race is third with 20 minutes Main....
Are you in Panama? That would be quite close to Florida. Join us for the WinterNats next year!
Sorry for the English
Re: Re: Re: Re: Switch to 710
[QUOTE]Originally posted by Sow&Steady
[B]Well, that is a very good record.
Are you in Panama? That would be quite close to Florida. Join us for the WinterNats next year! QUOTE]
Yes I am in Panama
Yes I am in Panama
anyone looking to buy a 710? I built a car and decided not to run it.
I have a post in the buy sell forum but I figured I would ask you guys here as well..
I am open to offers in the range of $350 or OBO. ( shipped)
Thanks.
Speed2004
Thanks.
Speed2004
Do i have to use the 61 spur with the 16 t gear? I cant seem to set the mesh right, my 16t wears out VERY fast, 1 hour or so?
Re: Re: Re: Re: Re: Switch to 710
Did you read my post on this forum? I had try all the top car and end up keep 710 as the one I drive. it is definetely a good car if you really know how to build a RC.
My user name already tell you what driving skill I have
and 710 survive my violant abuse
NTC3 is a good car for so many years, but if you want to try belt drive system, only those who do not know RC will have trouble with it.
Hey don't apologise, ... its better than my Spanish!
Yes, it will be tighter than normal initially but after running it for a while when it's running a little bit smoother, relax slightly on the meshing so that the pinion and spur turns a little smoother. It should be ok.
Re: Switch to 710
Originally posted by alan
Our local top guy also drive 710. All of them have change the dog bone to CVD. How about those factory driver? are they use dog bone? if so, what is the track width? Any modification?
Anyway like the others have mentioned, if you set the trackwidth correct and the steering end travel correct, you will not have problems with the dogbones.
What are you planning to use? Front ball diff, oneway or locked front axle? With the front ball diff, the car needs to be narrower like 197 mm in the front. You could put spacers like rcpanama has suggested but make sure that the front suspension does not bind and travels smoothly.
Julius also mentioned to put spacers in the wheel axle so that the dogbone does not sit in deep enough for the wheel axle to catch the dogbone and break it or dislodge it when you hit something at the same time your steering travel is at the max.
Cheers !
p/s: Don't set the diffs soft like the NTC3. Else, your diff will slip and you'll get a bad handling car. Refer to Julius' article on mytsn on how to build the diff correctly. You should not allow ANY slip on the rear diff or front diff and your car will track straight when you gas the throttle. BTW, the ball diffs on the 710 are much more rugged than that on the NTC3. Just build it correct on the first time (Mugen Super Grease).
Originally posted by KevinS
Who is your source? fastharry?
Any of you guys can explain why Serpent parts is so much cheaper now? The choices are other than they are made in China or you guys get fooled and robbed before
Originally posted by Pyramid
I believe the 2nd winner was Mr. Dhanu (Mr. Giant patners) using our partner`s G4 and the 3rd one is Mr. Fayakun (track`s owner). But none could give close competition to the first winner that will be coming to Brazil this year.
Forgot to `mentioned`. S710 on A2nd grid by Mr. Hendro atuaally was the fastest single lap timed on that final.
Originally posted by GoldFinger
... but it is true!!
The track is being resurfaced again with some emultion after having VHT 3 weeks ago so its become tackier ?
Especially in the some (shiny) spot. And if I noted there is no car that is not having tracktion rolled but it was a great track.
Now is danis24 turn! please give your comment.
Bad boy... j/k
1st heat underweighted.
He strap 2 dogbone on the top of front deck.
Originally posted by daniz24
Yes, and a teenager's single lap time almost the same as Mr. Hendro with only have driven the G4 for 1-2 weeks...
And I'm pretty sure going from what you say, if that teenager you're referring to drives the 710, he would have easily TQed.
In summary, what I'm trying to say is that on the top level, all cars are pretty much equal. Pros here, cons there. It's all the the driver's hands and capabilities.
Do you know that Mr. Dhanu is using 35 shore all round for the 45 minutes final?
