Losi 8ight building and setup
#6738
R/C Tech Elite Member
I run the carbon brakes on my 8B work great!
Now the Dif. set-up I use is for a large sometimes slick tight with big jumps track! Mills pond Fla.
3-5-1 yes one in the rear caus the Losi likes to step-out on power.
Now i come out on power and am able to square up for jumps better!
The 8b turns like crazy . I had to lessen my endpoints on stearing and have 0 toe! Still turns on a dime and comes out rippin! Try it youll like it!
#6741
How can i adjust my losi 8ight truggy for a dirt track? Because i just got my new car and it has a really really fast steering servos, and i noticed that on the front tires there is a lot of toe out, is that standard and if not can someone please let me know what a pretty standard toeing is for the front and back for a dirt track and i like lots of balance
#6742
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Update on running 5-5-5:
This made a bit of difference. Loose and dusty track conditions, the rear didn't "wash out" as much.
I also went down to the smallest rear bar... this was a bigger change than the diff fluid was.
The rear is pretty locked in now... some folks probably wouldn't like this setup, it doesn't "rotate" as good. It still turns in fine, but after the initial turn it, it is a lot more stable.
I think this is a good setup for an inexperienced driver (like me.) I was MUCH faster this way!
Note that this is on a fast track with a dusty hard-packed surface. When they watered (still breaking in the track for this weekend's RC Pro Texas Series race) it pushed a bit. Probably not a good setup on a very sticky, damp track, but it was VERY forgiving on a loose dusty track. That's a reasonable trade-off in my book.
Other setup info: 40wt / 54 piston /silver springs front, bones just a hair below level, 32.5 wt / 55 piston / green springs rear, bones just a hair above level. Front 1 degree toe out, 2 degrees camber, long ackerman, bump steer "cones up." Rear has adjustable hinge pin holders (Losi) with what SAYS is 3 degrees toe 4 anti-squat, but I've been told the documentation is wrong it is only 2 degrees of toe. (bushings are labeled 1) Front camber links inside on tower inside on hub. Rear camber links lower inside on tower, inside on hub. Swaybars black front, small silver rear. Significant front brake bias. Rear arms forward. (Shortest chassis setting) NO added weights. As much droop as I can get from the shocks on both ends- I set my arms so I have to compress the shocks maybe 1mm to slip them on the upper bolts.
You experienced drivers won't like this setup, it makes the car "lazy" (for a Losi!)
Beginners will benefit from this one. It makes the car much more forgiving to drive, especially on a slick, dusty track. There MAY be some settings on there that would be better another way... I'm open to suggestions, but, not planning to change anything before this weekend!
#6743
domit- if you are running 1 inserts faceing inward you are running 2 toe in the rear. If you are running this i would sugest putting in the 0 inserts for 3 rear toe. you can also move the hubs all the way back and that will give the car better roation comeing out of a corner but slow it down comeing in.
#6744
#6745
Cool il try that too, but will adjusting my wing at the back of my losi truggy really affect how the car handles or jumps because the slight adjustment really doesn't look like it will do anything?
#6746
Hey guys um i just encountered a huge problem because when i installed the engine the gear that is should show under the car to bump start it is to high up and the starter box cant reach it. Also the engine is a bit to far forward and the throttle is then getting in the way of a plastic piece and i have not idea what to do.
I have a losi 8ight Truggy with a axial .28 racing engine and a Ofna 1/8 Off-Road Truggy Starter Box Dual 775 Motors
I dont know what to do, it is possible that the engine is not made for the car and the box fits most models and not the truggy? Please let me know if anyone knows what to do?
#6747
There is a Losi Truggy thread too for any other questions you have about your truck.
#6749
What GRP tires are the Pros running at loose blown out tracks?
#6750
I found out something interesting this weekend... gonna have to give this a try:
As an inexpensive, readily available method to retain the CVD pins, one of the local guys is using "engine dust caps." Has anyone tried this? How did it work out for you?
