NEW XRAY T2
#1786
Originally Posted by Arun
Let's see some pics, Dave!
Or...
Maybe the better pics from you will be in a couple of months when you have a dremel and too much time on your hands !
Or...
You know me so well Arun! Im off to work soon ill post a pic or two tomorrow. Have you picked up a T2 as well?
- Dave
#1787
Originally Posted by scoobydo
What do you use to countersink the holes? Can I pick something up at the hardware store? Size?
There are alot of bits out there to do the job, and there are many sizes and degree angles. Lowes sells the bit that i bought for 10$, its an 85 degree bit, shiny silver in color, 1/2 inch drive, and it does NOT have a centering drill bit. Its very sharp and can do the job by hand, although a drill will make the job easier... the bit is sharp enough to ruin the gear with the drill. Your preference though. Just go slow. As stated earlier, ill add pics tomorrow when i get back from work.
- DaveW
#1788
2 questions..
-How is everybody running there battery wires over the top deck or through the middle? Which way is less likely to hit the belt.
-Also I was going to buy a new digital servo. Can anybody reccommend a good high speed one. Preferably one that mounts easily on the T2 and does not hang over the edge.. Thanks..
#1790
Agreed.
Originally Posted by R/C Anonymous
KO Propo has some nice digital equipment
I have had my KO servo for 3-4 years. They make great servos.
Go under the upper deck and use the battery brace to hold the wires down. I'm still wondering how I'll get my GTB wires and where I'll mount the big cap now that the belt goes over the upper deck. Anyone have a GTB mounted yet?
#1791
can you use the same springs you use with the 05 on the new T2???
#1792
Yep
#1793
Originally Posted by HRCRACER123
2 questions..
Futaba low profile servo is what i run, nice and small and the PT fits on the end
#1794
What are the specs and price on that...
Originally Posted by Scho
I run my wires under my top deck, no chance of it hitting the belt that way, and looks neat and tidy.
#1795
Hey guys, I raced my t2 for the first time today. After about 2 packs of practice It was dialed like my fk05 was.
The biggest difference I saw is the rear wheel isn't lifting... I always had to run anti-dive with the fk05 on high traction carpet. now I had pro-dive and the rear wheel wasn't close to lift. I'm in love. The drive train got even freeier after the day
Oh yeah just so you know, I tried some schumacher MI2 c-hub on the car and they fit very well. I was scared to break it so I had to find some parts. Just need to add a set screw for the lower pin, and the metals bushing fit perfectly. the knucle sit a little less than 1mm higher but I guess it would be better than nothing. they have some 6 deg too
#1796
Pics of my beauty.
#1798
FYI team tamale is on the job as always, got some 4.5degree aluminum hubs today
#1800
Originally Posted by lbckevin
I had no problems with my kit. I built everything last night. Took about 4 hours. I had to space the servo out a little, but Xray gives you shims to do so.
You cannot expect Xray to build a car to fit every servo on the market and fit every stlye of foam tire. Very simple , less than a minute fix, and the parts are included to space things for you. Nothing extra to buy.
I think alot of guys are here just to complain...shut up and race.
Team GP,
Thanks for all of your tiips....went smooth...
Kevin Smith
Team GP,
Kevin Smith
