JACO tire news
#407
Does anyone know of a place to get these tires? My local shop doesn't have them yet but I'd like to try them out.
#409
#410
Most distributors have received their orders by now, but all of them miscalculated the demand. We have gotten reorders and are in the process of filling them as we speak. By next week, most distributors should be restocked. There will be NO shortage of tires for Cleveland!! We are well stocked with raw materials.
#411
Jack,
I'm having trouble getting the steering balanced with 2 stage tires, I'm running the dble pinks all around an my rev4 (new style front end) It won't turn in hard enough but by the 5th minute it's a bear coming out of the corners. WAY too much and it still doesn't go in very well. I've reduce my caster and stood it up all the way to go in better, I'm running 5 deg reactive, my center spring is red and i don't want to go lighter as it will make it even lazier going in. I'm just about ready to go back to Purple / white combo but i do like how the two stage tires roll, the regular tires do not roll as well.
I'd be gratefull for any suggestions.
Chris
Chris
#413
Ampdraw is having a close out sale on their extra jaco tires they had at the iic race.
http://www.ampdraw.com/iic.shtml
I just picked up 8 sets (4 sets for the front and 4 for the rear).
#414
Originally Posted by crimson eagle
Jack,
Chris
Chris
What springs are you running in the front and what side springs are you running in the rear? Jim, OD and I are running two stage double pink front and rear and the cars are awesome!! We are running the old style front end with 22 front springs and I am running green side springs in the rear. I do not think I can get the car to be any better. Last weekend my car was the only car in the 11 second range on the current layout. In the last qualifier, I had five laps in the 11's.
I would try changing the springs first.
#415
crashby,
i started with green sides and 20 fronts. I changed to 22 fronts which was better, removed the unpredictability when entering the corner. I went to white sides which made it feel a little smoother.
According to the results you had a 12.56 and Jim a 12.3x. I got a 12.6 and I thought the car was horible, would not turn in worth a crap.
I'm getting another rev 4 conversion kit which I'll put the old style front end on and use for stock. If I can't make it work I'm going to go back to my old tires
Chris.
Chris.
#416
crashby,
Chris.
Chris.
Jeff
#417
crashby,
Chris.
Chris.
#418
Jack,
I'm getting a LOT of build up on the two stage tires (12th stock and sedan stock). We are using Calandra carpet and TQ Orange (only type allowed). The car seems to get slower as the evening goes on. I am cleaning with motor spray after each run. Is there a better way to clean the tires? Our track has a lot of bite, but not as much as Vegas. I'm willing to run fresh rubber each run (and then clean them all at home) if I have to, but would prefer not to do that.
#419
Hi Jack,
I heard from someone at my local track that your tires and hubs are guarantied not to break, Is this true ? and if they do break that if we send them back to you, that you will replace them free of charge. I did not believe him and threw them away.... If it is true, I will save them next time it happens.
BTW, your tires are the only things I use... their great
#420
Jack Rimer
whats the story on TRC and Jaco. I heard stuff this weekend about you teaming up with T or something, read on another thred you might have sold the company. Then I think you posted something that the 2-stage tires will be sold at the trinity table at clv... Can you comment ?
