JACO tire news
#601
The 26mm tires are very popular since the introduction in Vegas, Since then our full team has run them in every class ( Stock, 19 and mod) with very strong finishes and major event wins.
The wheel is very very strong, and with people getting use to the changes you need to make when running the 2 stages tires, we are hearing only good things about them from racers
Hope this helps.
Korgae
Hope this helps.
Korgae
#602
Hope this helps.
Korgae
Hope this helps.
Korgae
#603
Thanks for pointing that out, We will get it changed asap.
You are correct, it should be JAC4160 Double Pink/Orange Front.
With the matching rear being the JAC4156 Double Pink Rear.
#604
Hope this helps.
Korgae
Hope this helps.
Korgae
#605
IMO there are two reasons foam tires tear from the rim or from the wrap.
A. You're tapping boards and the foam tears from the rim for the obvious reason. Thsi will happen no matter what glue you use or how well set up your car is.
B. You're not hitting boards, but your wheel is rolling over too much in cornering causing the foam'rim seperation.
The solution to A is to practice and driver cleaner.
The answer to B is some combination of either more static camber and/or more negative camber gain (raising the outer camber link up)
Someone please correct me if this is incorrect. It is just based on my experience.
#606
Team EAM
Originally Posted by Kave
Have people found a way to prevent them from pealing after anywhere from 2-4 runs?
If you do want to glue the sidewalls in extreme traction cases then after you cutt the sideway down and before you round the edges take the wheels off the truer and glue the edges good. Then put them back on the truer (after glue has dried) and round your edges. Then you will come out with perfect CA and no peeling!!
EA
#607
Trader Rating: 20 (100%+)
i do the same sequence as EA.. but i actually allow the rim to stick out just a little... almost beveling the tire ever so slightly.. definately round the corners helps a lot!!
EA!! your wife was really twisting my arm to make it to VEGAS this year she said to bring my girl also..... gonna be a girls' night out or something...
(we were hanging out the last night at THE BAR playing pool with ya!!!)
arvin
arvin
#609
I do pretty much the same as EA, but I started doin it cuz I just didn't like the tire hangin off the rim like that, and mine seem to be stayin together pretty well. I haven't put the tire back on the truer after gluing tho. I just glue the inner wrap on the rear, and just past the wrap on the front. Again, if you need to get rid of some side bite, try going higher with the glue.
EA, why would you wanna wait for the glue to dry before putting the tire on the truer?
Vegas was good times! The girls seemed to be on a roll out there this year.
#610
Does anyone have shore rateings for jaco 2 stage 1\12th tiers? Thanks
