Xray T1FK05
#901
RX
I mount the Rx on top of my servo in my 415 and have no problems at all. I think you will be fine.
#903
hey guys just out of curiosity does the rear diff come assembled for you at the factory like the FK04 did?
#905
Originally posted by A.c racing
yes, both come assembled for you already....
#906
Re: Re: Brushless in an Xray?
Originally posted by danjoy25
Depending on your controller. I use a Schulze U-force 75 with no problems at all.
#907
what size 64 pitch gears can we use on this bad boy, if any?
I hear 112 is the highest ?
#909
Re: Electronics Placement
Originally posted by rctoyguy
OK yall, looking for help in electronics placement... I can't afford a fancy new tiny RX or ESC - LOL...
With the RX where it is, the transponder wire ain't long enough to reach, and I don't think the ESC is going to fit there - it is slammed against the RX wires on one side and right on the edge of the motor area on the other...
How bad is it to put the RX on top of the servo? What about moving the antenna? That would let me move everything forward, and might fix it.
#910
Please see the forum rules re: advertizing, thanks!
#912
116 is the largest.
#913
Today I weighted my ride and it is 1425 grams. Where shall I install the additional weights. I know it has some holes on the sides (behind the motor and behind the battery) and also I can see two holes right below the rear belt. But what about the front of the car? I cannot add all of it in the back. Can anyone help here?
Thanks a lot.
I 'll post that on the xray forum too.
Thanks a lot.
#915
Funny John
