Like Tree1Likes
Xray T1FK05
Old 03-24-2005, 06:47 AM
  #916
kidDynomite's Avatar
Default Re: Electronics Placement
Originally posted by rctoyguy
With the RX where it is, the transponder wire ain't long enough to reach, and I don't think the ESC is going to fit there - it is slammed against the RX wires on one side and right on the edge of the motor area on the other...
How bad is it to put the RX on top of the servo? What about moving the antenna? That would let me move everything forward, and might fix it.
rctoyguy, I would suggest releasing the capacitor from you ESC and mount the cap to the top of the ESC or the top deck. This will let you move the ESC in closer to the center of the chassis as well as protect your switch. Maybe turning your RX on it's long side. Don't forget to seal the big, cracked hole in your RX too.
On all my Personal Transponders, I put Deans Micro connectors so I can switch them from car to car. This way you can make the wire the perfect length. I also mount the PT right behind the bumper in front of the diff and route the wire along the chassis to clear any moving parts.
Hope this helps.
kidDynomite is offline
Old 03-24-2005, 06:55 AM
  #917
Originally posted by dway100
I was just wondering how stiff the stock chassis and upper deck are. I know they are offering the optional 3mm chassis and wide upperdeck, but are the stock pieces stiff enough for carpet w/foams?
It feels pretty stiff to me, a lot more than the stock 04. I would think that the new wide top deck would do the trick. But if you want to go super stiff and a larger spur, get the 3mm bottom chassis for sure.
Old 03-24-2005, 07:07 AM
  #918
Registered User
Pyramid's Avatar
Originally posted by aantonis
Today I weighted my ride and it is 1425 grams. Where shall I install the additional weights. I know it has some holes on the sides (behind the motor and behind the battery) and also I can see two holes right below the rear belt. But what about the front of the car? I cannot add all of it in the back. Can anyone help here?
Thanks a lot.
I 'll post that on the xray forum too.
Try to find the unbalance side between L/R first.. use that small hudy tool. After you know which side, you would have better idea to place additional weights. Preferable in front of the car for more steering.
Pyramid is offline
Old 03-24-2005, 07:17 AM
  #919
aantonis,
Is that total weight with rubber tires or cut foams? ROAR rules: rubber/1524g vs. foams/1418g
If you're using 3300 and 3700 packs, you may want to mount some weight to the packs themselves so the car will be balanced side to side no matter which pack you run.
If you don't have balancing pins or scales, you can figure to put all the additional weight on the roof of your lexan body. I hear that's what everyones doing. lol!
I have yet to put on all my electronics and set the car up, but once I do, I can give you more details as to where all the weight is at from side-to-side, front-to-back, and per wheel.
Old 03-24-2005, 07:27 AM
  #920
The total weight under EFRA specs with rubber tyres is suppose to be 1500grams without a transponder or 1515 with a PT.
aantonis is offline
Old 03-24-2005, 07:43 AM
  #921
kt racing's Avatar
I have a 120 gear in mine just had to file the top plate just a little to not rub.
kt racing is offline
Old 03-24-2005, 07:45 AM
  #922
Default Spur gear
Does the 120t stick out the bottom?
brianrice is offline
Old 03-24-2005, 07:47 AM
  #923
How come they don't include the PT with total weight? I would try the weight setup that's on Xrays rubber setup sheet. It looks to be mostly down the center.
Old 03-24-2005, 08:36 AM
  #924
rayhuang's Avatar
Thanks a lot.
If you send me your car-I'll put it on my Hudy balancing blocks-then I'll send the car back to you in about 10 days perfectly balanced. btw-I run a Helios 75mHz radio-can you make sure you send it w/ a compatible receiver??
rayhuang is offline
Old 03-24-2005, 08:41 AM
  #925
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
Ray, you getting one of these bad boys? I'm jonesing for one REALLY bad right now.
dr_hfuhuhurr is offline
Old 03-24-2005, 08:42 AM
  #926
theisgroup's Avatar
going to get one? I figured ray already had his built. I mean it is a new car out on the market almost a week now.
theisgroup is offline
Old 03-24-2005, 09:38 AM
  #927
Jimmy Morris's Avatar
Heres mine.
Jimmy Morris is offline
Old 03-24-2005, 09:39 AM
  #928
1 more. Boy does this car look sweet.
Old 03-24-2005, 09:43 AM
  #929
rayhuang's Avatar
Suprisingly enough-not yet.
I could buy one tonight at AJ hobbies-but I have a pre-order in on the JRXS and a full spares inventory. If i get one it wont be till June or so.
Ray
rayhuang is offline
Old 03-24-2005, 10:21 AM
  #930
Ordered mine at lunch. Now I just have to finish all this other work so I can have time to build it. It will be a good carrot for the time being to prod me along.
Blake
