Xray T3 2012
#2026
should you use the plastic clips? over the pins in the outdrives?
#2030
The XRay version works great too. Just keep an eye on your blades, replace them before they break.
http://www.teamxray.com/teamxray/pro...p?prod_id=4012
The blades always stick out slightly from the outdrives so they wear a groove in them.
#2031
I have brand new nikita outdrives for sale 35 usd shipped
#2032
I didn't experience issues with the blades breaking with the Aluminum outdrives and I have been using these for the past few months without issues as well: HUDY Spring Steel Lightweight Adapters
#2034
wow, that's a good deal! thanks for the tip!
thanks still dude
super thanks
super thanks
#2035
Check the rubber insert/O-ring/membrane. I had this happen to me when i first built the car, i do not use foam inserts either and from what i found, the membrane was not seated correctly into the shock between the body and the cap. This cause it to stretch, and once it reached a certain point, it began to leak, this caused some really bad handling issues and costed me alot of track position. I hope your problem is as simple as mine was! Good Luck and i hope this suggestion helps! -Randy Banks
#2036
While were talking out drives, I don't mind that the plastic spool out drives brake, it saves more expencive/harder to repalce parts of the transmission, and normally, I've only ever broken them when I have a 'moment' and hit the wall. I've also noticed that the plastic out drivers will wear internally and notch, like any other non-blade equiped out drive, the trick is you can't see the wear, carefull inspection is required, but again, the life of these can be 50+ packs.
#2037
Ballcups
Do the ballcups on the 2012 seem to be better and have enough clearance or are people sticking with the old flat ones?
#2038
(which for me atm is yearly)
#2039
Short of the setup that the Schumacher Cats and Losi off road buggys from many years ago had, uni joints at the top and bottom of the shaft and a telescopic section in the middle, the blades seem to be a perfect solution. Replace a plastic part that costs under $10 for 4 or, after a similar amount of milage replace some expencive steel/alloy parts.
#2040
The best solution I have seen so far for the outdrives/driveshafts is the way Awesomatix have done it.
They effectively use a bearing on each side of the driveshaft instead of blades so the movement is absorbed by the bearing.
Skiddins
Skiddins
