Xray T3 2012
#2012
Hi, can anyone tell me if there was a fix or a Reson for the rear toe being different on each side in a new Biuld, I have a 1.5 deg diff from left to right, I can add shims to make the same, but was wondering if there is a Reson.
#2013
Alternatively you can buy a single piece block like it has in the front or just use shims to get the toe you want.
#2014
Thanks mate, I'm new to X-ray from a tc6 so having some learning curves.
#2015
My car has been pretty solid with one exception. The spool cups are made out of crackers. find some after market ones (alum or steel) or keep spares (btw - speedctech sells ones by R1 that are good and durable). It's always a good idea to have an extra set of arms on hand too
#2016
#2017
#2019
Is this what your talking about? http://www.speedtechrc.com/store/ebp...d=816&id=12480
#2020
Mira outdrives are for the Photon to use XRAY ECS..Nikita outdrives are the ones you want for an XRAY.
http://sidepieceracing.com/products/nikita/
#2021
#2022
The XRay version works great too. Just keep an eye on your blades, replace them before they break.
http://www.teamxray.com/teamxray/pro...p?prod_id=4012
