Like Tree1Likes
Xray T3 2012
Old 04-01-2012, 12:53 AM
  #1996
Wtb: xray t3 2012 chassi,
Options and extra is welcome!
Pm to tell What you have to sale!
Zooberg is offline
Old 04-01-2012, 01:20 AM
  #1997
alecladanga's Avatar
hi guys
finally upgraded my t2 09 to a t3 12! :-)
just like to ask again (if this has been asked a million times), that if we are NOT to follow the manual in terms of filling up the gear diff with oil using weight, what percentage would you determine to say the oil in the gear diff is already sufficient?
Say, 50% - 80%? or do we fill it up like the way we fill up the spec r gear diff, until the oil reaches the cross section?
many thanks in advance.
alecladanga is offline
Old 04-01-2012, 01:39 AM
  #1998
R3VoLuTiOn's Avatar
Trader Rating: 29 (100%+)
sounds...ok.
itll just leak out if you've overfilled anyway.
It seals better without the thin O-ring for my nt1 and t3 diffs.
R3VoLuTiOn is offline
Old 04-01-2012, 01:51 AM
  #1999
nerdling's Avatar
Originally Posted by alecladanga
hi guys
I fill the diff, use a shock pump to remove the air then assemble and wipe up the excess.
nerdling is offline
Old 04-01-2012, 03:06 AM
  #2000
hi guys
I built my gear diff asper the instructions and didnt have any problems at all. Why are people saying not to follow the xray instruction manual ?? have I missed some thing.
FLAT OUT is offline
Old 04-01-2012, 08:15 AM
  #2001
Bigz84's Avatar
Trader Rating: 24 (100%+)
Default and sweep
for those who are running arm sweep, are you seeing more mid corner/exit steering? I was running a stock front end, 1 degree toe out. I put a .4 shim in the front block, and kept the 1 degree toe out, and could see more steering in mid/exit. I just want to make sure I'm seeing that right. It also seemed like the rear got a little loose w/ the arm sweep, what can be done to keep the arm sweep, but keep the rear planted like it was w/o arm sweep?
any info would be helpful, thanks
Bigz84 is offline
Old 04-01-2012, 01:42 PM
  #2002
stro3579's Avatar
Trader Rating: 20 (100%+)
Default Shocks
Is anyone having issues with the shocks leaking oil? I am running my shocks without the foam insert and I am noticing after a couple of runs the oil is leaking on the shocks. Any suggestions?
stro3579 is offline
Old 04-01-2012, 02:05 PM
  #2003
Trader Rating: 38 (95%+)
Default xray t3 for sale
http://www.rctech.net/forum/r-c-item...t3-2012-a.html
zaraz is offline
Old 04-01-2012, 07:32 PM
  #2004
R3volution, nerdling and Flat Out: many thanks for the reply, much appreciated. I can't build the geardiff 100% as per the manual instruction since i don't have a digital mini scale :-)
Old 04-01-2012, 08:13 PM
  #2005
Trader Rating: 19 (100%+)
Check the rubber insert/O-ring/membrane. I had this happen to me when i first built the car, i do not use foam inserts either and from what i found, the membrane was not seated correctly into the shock between the body and the cap. This cause it to stretch, and once it reached a certain point, it began to leak, this caused some really bad handling issues and costed me alot of track position. I hope your problem is as simple as mine was! Good Luck and i hope this suggestion helps! -Randy Banks
COLD AS ICE is offline
Old 04-01-2012, 11:53 PM
  #2006
sagejyoung's Avatar
same! i fill the diff to the cross, vacuume and seal. i have run the oring, but when i rebuild to change the oil to something lighter i will leave it out. less rotating mass.
sagejyoung is offline
Old 04-02-2012, 05:32 AM
  #2007
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
Go to ebay and find one. I picked up one for about $6 shipped.
dr_hfuhuhurr is offline
Old 04-02-2012, 05:45 AM
  #2008
nerdling's Avatar
Sorry, should have been clear I did not use the scales when I built the diff
nerdling is offline
Old 04-02-2012, 08:19 AM
  #2009
M-Technic's Avatar
Trader Rating: 15 (100%+)
hi guys
I put the cross section in, and fill to about 1/4 to 1/2 up the side of the cross section. If you overfill the diff, that is when it leaks.
Why use a pump? Unless you really overfill the diff there is going to be air in there, so that is probably an unnecessary step.
M-Technic is offline
Old 04-02-2012, 11:41 AM
  #2010
gawith0413's Avatar
Trader Rating: 86 (100%+)
Just bought my t3 12. What do I need parts wise (I know what motor/esc and servo I'm getting)? Basically what's good to have right off the bat. Thanks
gawith0413 is offline
