Like Tree1Likes
Old 04-17-2012, 05:55 PM   #6601
Losiho's Avatar
Dumb question - how are you guys achieving such a low FDR ? I'm running 21.5 boosted class, and the biggest pinion I can physically fit with the 80 tooth spur is a 30 tooth (5.33 FDR).
What brands of spur gear are you guys using ? I assumed the AE TC6-style spurs were the only type of spurs that fit, because of the hole in the spur needed to access the motor mount screw.
What am I missing ? Will "regular" Robinson / Kimbrough-style spur gears fit, and still allow access to the motor mount screws ?
Losiho is offline   Reply With Quote
Old 04-17-2012, 05:56 PM   #6602
Timbulb's Avatar
Use 64 pitch spur and pinion and use the 3rd motor mount screw hole.
Timbulb is offline   Reply With Quote
Old 04-17-2012, 06:02 PM   #6603
evochick's Avatar
I am currently using RW spurs and pinions in my 6.1,
for 21.5 non boosted a 66-68 spur and 40-42 pinion depending on track,
Beth.
Unretired
2017 ACT Rally champion :)
evochick is offline   Reply With Quote
Old 04-17-2012, 06:18 PM   #6604
jirish617's Avatar
Trader Rating: 20 (100%+)
Originally Posted by LasagnaCat View Post
Stick with the caster blocks you have. The TC5/6 blocks are stronger, and are in stock everywhere if replacements are needed. Some of the 6.1 parts have had breakage issues and spares have often been hard to come by.
A gear diff in the rear would be a nice first addition (and some of the Reflex soft shock bladders) but it will be absolutely fine as-is. Get a good setup on it and go from there.
okay thanks, its actually coming with a rear gear diff and front spool. It'll be probably 2 weeks till I get there with my car, maybe 3 because ill be waiting on stuff, but i might make it saturday to test my dads that he just got if i get out of clinicals early enough
jirish617 is offline   Reply With Quote
Old 04-18-2012, 06:24 PM   #6605
MikeR's Avatar
Trader Rating: 15 (100%+)
http://www.exotekracing.com/prototype-tc6-project/
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 04-18-2012, 06:32 PM   #6606
Losiho's Avatar
I managed to round the head of the 2.5x8mm button head screw and had to remove it but cutting a flat head groove with my Dremel.
Is there any reason why the spur gear button head screws (ASC31521) are out of stock everywhere ? Tower Hobbies shows it as discontinued
Old 04-18-2012, 09:06 PM   #6607
Grassy's Avatar
Originally Posted by Losiho View Post
You can use thundertiger part# PD9007 this is the same screw or PD9006 this is the same size but is a cap head style with a 2mm hex drive (i prefer this one)
-ACE HOBBY DISTRIBUTORS AUSTRALIA-
Grassy is offline   Reply With Quote
Old 04-18-2012, 09:14 PM   #6608
Losiho's Avatar
Thanks. I've managed to source some Top Racing screws, which are identical to the OEM Associated screws -
http://rcmarket.com.hk/product_info....ducts_id=10221
Old 04-19-2012, 08:02 AM   #6609
Rockin G's Avatar
I just picked up a TC6. The guy I bought it from had it mostly built. I am going through setting it up now. The problem I am running into is that I cant get the turnbuckles short enough on the rear. This is my first Associated ever, and it has been 10 years since I messed with a touring car for that matter.
Anyways, I took of the turnbuckle to see if the wrong ones were put on the back but comparing them to the other ones on the car. After I adjusted them as far in as I could, they are definately shorter than the other ones on the car. I am guessing that the way the sit, they are at about 3-5 degrees of Positive Camber. Turnbuckle is mounted in hole #1, so I dont have that adjustment to play with. Any suggestions? Thanks in advance.
Rockin G is offline   Reply With Quote
Old 04-19-2012, 08:10 AM   #6610
RussF's Avatar
Trader Rating: 21 (100%+)
According to the manual the rear turnbuckles go in #7 which is on the bulkhead. Thats the factory setting anyway and I think you need shorter trunbuckles to use the other holes 1-6. If you dont have a manual you can download one from AE's site. It shows the length of each link and you can compare what you have to that. hope that helps, I'm kinda new at the TC6 myself.
SaltLakeMini-Z.com, HowFastAreYou.com
RussF is offline   Reply With Quote
Old 04-19-2012, 08:21 AM   #6611
Is it possible that the previous owner, or you, accidentally mixed up the turnbuckles and put the front ones in the rear and the rear ones in the front? I have seen this happen before and it causes this type of problem.
rc_speed is offline   Reply With Quote
Old 04-19-2012, 08:23 AM   #6612
Rick Hohwart's Avatar
This is correct. The turnbuckles provided in the TC6 kit are designed to be used
with the #7 setting.
www.reedypower.com
Rick Hohwart is offline   Reply With Quote
Old 04-19-2012, 08:29 AM   #6613
Rockin G's Avatar
Deleted, accidental double post
Last edited by Rockin G; 04-19-2012 at 08:33 AM. Reason: Got too creative on multi-quoting
Old 04-19-2012, 08:31 AM   #6614
Rockin G's Avatar
So then I guess I need shorter turnbuckles, or atleast rod ends to run the other holes. When I look at the set up sheets from the other drivers, they use the other holes. I guess that is why I was trying to get to hole # 1
It is possible, but I compared them, and the ones on front were longer compared to the ones I took off the rear...which would give me more. I was too tired to think anymore on it, and now I am at work and the car isnt here for me to look at. I will work some more on it tonight. Looks like I may need hole # 7 in the meantime.
Thanks Rick. Please excuse my ignorance. Been too long, and so much has changed. So am I looking for shorter turnbuckles or rod ends when I head to the hobby shop? Thanks fellas
Old 04-19-2012, 08:36 AM   #6615
Stick with the standard rod ends but use a shorter turnbuckle. In some cases you will run the #7 hole in the front. Generally the other holes are used in the rear.
www.reedypower.com
THE TRACK RACEWAY Apex Mid Atlantic RC Racing 28970 09-28-2017 07:28 AM
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Team Associated TC6 KostaG Electric On-Road 8 07-04-2010 11:42 AM
