Team Associated TC6 Thread
#6751
Has anyone tried to mount a VTA body on a TC6? I picked up a used one to run in VTA but the front body posts are way to short to fit the VTA body. Is there something longer that will fit? Im sure I can piece something together, but I just thought Id ask to see if there is something that is an easy bolt on solution for a taller front body post. Its hard to tell how long the posts are looking at pictures n the internet and Im sure someone has already solved this.
Thanks in advance.
Thanks in advance.
#6752
I use the associated bulkhead shims under the body post to raise it up a bit.
Thanks in advance.
Thanks in advance.
#6753
Perfect. Thanks Guys. I ordered set of the HPI posts. They looked the longest and I can always cut them down. The AE posts looked to only be 1 hole longer than the stock posts and I wasn't sure that was enough.
#6756
Can anyone help me pls. I want to know the comprehensive list of upgraded parts the tc6.1 has over the tc6 - The petitrc list and the Team Ass. sites don't list the gear diff and outdrives etc. Also did the 3 hole vertical rear diff top brace come out with the tc6.1 or is it a factory aftermarket item?
#6757
http://www.teamassociated.com/news/a..._TC6.1_FT_Kit/
#6758
Noticed the stock chassis was narrowed to 88mm. 4mm on each side shaved off? To reduce chassis rub? By Narrowing it does the chassis become more flexible? Thanks
#6759
#6760
narrow chassis is not easy to touch the ground when cornering
#6761
Here is parts list for upgrade to TC6.1 as posted by Associated:
The tc6.1 kit comes with these parts in the box - tc6.1 owners please add other parts it comes with
784695 313569 #31356 TC6.1 Front Arms $7.99 January 2012
784695 313576 #31357 TC6.1 Rear Arms $7.99 January 2012
784695 313583 #31358 TC6.1 Caster Blocks $7.99 January 2012
784695 313590 #31359 TC6.1 Rear Hub Carriers $6.99 January 2012
784695 313606 #31360 TC6.1 Steering Block, 1pr. $5.99 January 2012
784695 313613 #31361 TC6.1 Offset Arm Mounts $8.99 January 2012
784695 313620 #31362 TC6.1 Anti-roll Bar Set $27.99 January 2012
784695 313637 #31363 TC6.1 Anti-roll Bar Tube $8.99 January 2012
784695 313644 #31364 TC6.1 Anti-roll Bar Wire, qty 4 $9.99 January 2012
784695 313651 #31365 TC6.1 Anti-roll Bar Mount, qty 4 $3.99 January 2012
784695 313668 #31366 TC6.1 CVA Kit $29.99 January 2012
784695 313675 #31367 TC6.1 CVA Rebuild Kit $6.99 January 2012
784695 313682 #31368 TC6.1 CVA Bone, qty 2 $14.99 January 2012
784695 313699 #31369 TC6.1 CVA Axle, qty 2 $9.99 January 2012
784695 313705 #31370 TC6.1 Axle Crush Tube, qty 4 $3.99 January 2012
Rear Gear Diff
Rear outdrives to suit rear diff
Front solid spool
Front outdrives to suit front spool
#6763
#6764
Rick, correct. Between riding curbs and a fast sweeper my car was dragging a lot, and sometimes would catch and spin out, the narrower chassis reduced that. It does flex a bit more so i went back to a regular upper deck (instead of one cutout (front and back) as we usually run. I must thank Dawson and FJ for their help (its always nice to hear what my car does wrong) after a few weeks of heavy testing i was very happy with the car
#6765
