LRP Vector x12 Brushless Motors
#467
It is a definite part from the outside of can and not rotor.
#468
You're definitely right about not coming from the rotor because as mentioned earlier,it is about the a quarter size of the circumference of motor can.
It fell out from the motor can when I pulled apart so definitely somewhere from within. But where does it go back is the question.
#469
when you opened the can (shaft side) first did it come from that side or the other (which is the endbell side)
I 'll have to open one of my LRP to check what it can be, except if someone has an answer for you first.
#470
It came from the shaft side,not the endbell.
I can't imagine trying to put it back because when I open the motor can,the shim immediately zapped to the rotor. That's another reason why I can't see where it was original from.
Normally I'm quite careful about disasseblimg parts but maybe not this time!
#471
Did you remove the rotor to check inside?
#473
I had a set up that ran 175-180 and faded badly, when I went down to 150-155 the fade stopped. Was running 1/12th with a Black Diamond V1 on 5, 2 dot insert and 71.5 rollout. Had to go to 4 dot insert, 62 rollout, and open the scoop in my AMR to get there.
#474
Mobile suit, you need to glue this part at the top, right in the center of the gap, i glue with cyano, without problem.
Here, with 4 dot insert go up to 190+ without fade.
Regards, Luis C.
Regards, Luis C.
#475
luic: it seems CA is the magic cure for this,thank you
Still wondering why they have it at first place and it would be good if LRP could update their instruction manual to show this too.
I'm guessing these shims only appear in the Octa Wind version?
#476
Yes, only in Octa, and basically, to have more magnetic power (over copper), need more iron core, sorry my english is not good, and less for explain technicians.
Regards, Luis C.
Regards, Luis C.
#479
17.5 Profile Suggestions
I bought 2 LRP SXX v1 used recently. I have2 x-12 17.5 motors, one in my RB5 the other in my RT5. I was wondering if someone could help me out with some prfile setup tips for running these on a clay indoor track using ROAR stock rules. Any help isappreciated.
#480
