Tekin RS ESC sensored
#3391
maybe an idea for tekin to design a fan for mod drivers.
Will keep you posted on the fan khale
#3392
i'm going to 5,6 and try also 5,8
than i'm going to try a tekin redline with 6,2
that motor has by far the lightest gearing.
here they drove with a spx and a Tekin redline 10.5T a speed of 48.2mh
This was with 5 cells.
with testing the spx and the Tekin RS the speed was the same just like the lap times.
#3393
i put the fan with 3300 mf capacitor together. actually i attached 2 fans for motor and 1 fan for esc with cap together and soldered it with the battery wires to esc. i liked it...
#3395
the only disadvantage is as i can see, now i can not control the fans by the on off button of the speedo.
during the race, my friend who gave the pit should attach the battery and opens the speedo just 10 seconds before the race.
#3399
20 smoke,
That sounds like the file is mis-named somehow... what is the exact file name of the zip file you're trying to open? You might need to unhide extensions (in XP, you'd go into "folder options" and click the "view" tab, then UNCHECK the "hide extensions for know file types" checkbox...) Vista should be something similar...
I have a feeling there's a hidden ".pdf" extension on the filename that you're not seeing...
#3401
It could also be that his file association for .zip got messed up and is now associated with Adobe.
