Tekin RS ESC sensored
#3407
Vista "How to video": http://www.youtube.com/watch?v=tTp3tUL9u8Y
Winrar download: http://winrar.ed0wnloads.com/
You will need an unzipping tool, vista does not come with one.
#3412
Zipped,TXT, Vista, XP? its all good amongest friends!
This Tekin 194 update sounds all too familiar to me. I have an HP laptop w/Windows XP, and slow/old dialup modem ISP. When I recieved 194 in Zipped form, my conputer could not deal with it. Contacting Randy did not solve the problem, However, what did wind up working was, another Tekin user locally, was able to email the program to me in TXT form. It responded instantly, Problem solved.
HTH
HTH
#3413
HTH
HTH
STLNLST, I think I need to look for a new ride so to speak. I ended the day on the last run with a broken caster block. I need to get a few parts like a spool and some spares if I'm going to move forward with the car.
I did get it to spool out to 36 mph by the end of the day so the car was starting to free up!
#3414
HTH
HTH
Sorry for the confusion, that is "I was confused", at any rate I was able to successfully update to 194, not sure why XP could not deal with converting from TXT to Zipped...Oh well.......
#3418
Randy
Today I ran into a problem with the RS ESC I wired it up for a brushed stock motor as per instructions and I set the ESC to forward with brake only. it ran fine for 2mins then it stopped I looked at the esc and leds 1&2 and 6&7 were flashing. when I hooked it up to the hot wire it showed I was still on brushed fwd only. any ideas?
Gorden
Gorden
#3419
This is now one of the many reasons I send it out in a .txt format to begin with.
#3420
i see you have a 10v cap. Should that not be 16v? I have no idea but the standard cap was 16v330. I installed a 16v2200 cap after mine exploded with a 4.5t brushless
