Tekin RS ESC sensored >
Old 04-12-2009, 09:34 AM
  #3241
Hi Randy
I'm going to use the RS with a stock brushed motor. Will the timing settings affect it? if so were should I start it out at.
thanks
-=light=-
light is offline
Old 04-12-2009, 01:21 PM
  #3242
Trips's Avatar
Trader Rating: 16 (100%+)
The timing of a brushed motor is controlled entirely by the brushes and commutator. The timing settings in the speed control have no effect on a brushed motor.
Trips is offline
Old 04-12-2009, 01:23 PM
  #3243
Thanks for the info.
light is offline
Old 04-13-2009, 06:02 AM
  #3244
Unhappy Brakes!?
Hey All,
Been playing with my speedo settings since i last posted about this, but i'm still struggling to get any brake strength.
I've tried 5 different motors and both v189 and v194. On the bench the brakes seems and sharp, but once it hits the track and put some weight behind it, they're incredibly weak to the point of being closer to drag brakes!
for my current settings, see attachment.
Any suggestions would be much appreciated as im desperate for some kind of breaks!
I would also add, that one of the configs i've tried, is the RS, Tekin redline 13.5 and the tekin 3400 lipos
TIA
Ian
DaSloth is offline
Old 04-13-2009, 06:35 AM
  #3245
C5Vette's Avatar
Not sure if it will help, but did you try turning the push control off?
C5Vette is offline
Old 04-13-2009, 06:54 AM
  #3246
i only put push control on since having 1.94 so yep thats been done and it didnt help.
DaSloth is offline
Old 04-13-2009, 06:56 AM
  #3247
rcterp's Avatar
Trader Rating: 35 (100%+)
Originally Posted by DaSloth
Hey All,
TIA
Ian
Do you have the brake % turned down on your radio?
rcterp is offline
Old 04-13-2009, 06:59 AM
  #3248
Nope, i actually set it from 100% to 120% on sunday and then re calibrated the speedo to that, just to be sure.
The lights go all the way down to end when braking and as i say, when under no load, the brakes are instant and sharp.
Thanks for the suggestions so far guys
DaSloth is offline
Old 04-13-2009, 07:37 AM
  #3249
Kenny L's Avatar
What radio are you using? You may want to try turning your neutral width to around 20 and keep reseting your radio to esc
Kenny L is offline
Old 04-13-2009, 07:42 AM
  #3250
i'm using the futaba 3pk and i've also tried a KO Universe 3. Neither seem to help, but ill try a bigger NW this weekend.
ta
DaSloth is offline
Old 04-13-2009, 07:54 AM
  #3251
pakk's Avatar
Trader Rating: 80 (100%+)
when you hit full brake, do all the lights light up then start blinking?
--pakk
pakk is offline
Old 04-13-2009, 07:57 AM
  #3252
Kenny L's Avatar
ta
The 3pk is known to have braking issues with nw less than 20 so that should be your fix. Hope that helps
Kenny L is offline
Old 04-13-2009, 08:03 AM
  #3253
--pakk
No
But they do now!
Thanks guys, hopefully this is the fix im looking for. this is why i love using tekin products
DaSloth is offline
Old 04-13-2009, 08:11 AM
  #3254
pakk's Avatar
well your ESC does not think you are pushing full brake. So try doing that initial radio setup thing where you hold down the mode button as you turn it on.
--pakk
pakk is offline
Old 04-13-2009, 08:26 AM
  #3255
--pakk
I'd done that quite a few times, but obviously didnt fully register it till i took Kenny's advise and changed the neutral width.
DaSloth is offline
