Yokomo MR-4TC SD >
Yokomo MR-4TC SD
Like Tree12Likes
Yokomo MR-4TC SD
Old 05-09-2003, 12:45 PM
  #1186
mo
mo's Avatar
I use chassis film on the front and rear 2-3" of the chassis. That is all that usually hits and you don't have to do all that trimming.
mo is offline
Old 05-09-2003, 12:47 PM
  #1187
utieh's Avatar
i think u should, i noticed that the vibration of my esc against the SSG created some traces, just imagine the result if i didnt protect the chassis, actually i added a lexan plate under the chassis, it is wider so it also protect the edges of the bottom plate (it makes ut car heavier too but i think it worths enough for 3 more grams)
utieh is offline
Old 05-09-2003, 12:49 PM
  #1188
rc-zombies's Avatar
Default MOTOR HEATSINK
Tamiya EVO motor heatsink is a perfect match for the car..
see the other photos as well...
Front and rear MIP CVDs fit perfect!
rc-zombies is offline
Old 05-09-2003, 12:54 PM
  #1189
IH
IH's Avatar
Good idea Mo! Thanks.
IH is offline
Old 05-09-2003, 01:04 PM
  #1190
utieh's Avatar
rc-zombie, what is the reference of the CVDs
on which kind of surface are you running (just watching ur spring set up)
thanks
Gilles
utieh is offline
Old 05-09-2003, 01:08 PM
  #1191
rc-zombies's Avatar
thanks
Gilles
Using Mo's setup for asphalt.
I got the CVD's off ebay for cheap... so I just put them on..Plus they are more durable than the Yokomo bones.
Old 05-09-2003, 01:14 PM
  #1192
utieh's Avatar
thanks
the hobby shop where i ordered the spring didn't have the green one in stocks so i just have orange+yellow. are the silver stiffer than the yellow?
utieh is offline
Old 05-09-2003, 01:18 PM
  #1193
mo
mo's Avatar
Yes, the silver is a litte stiffer than Yellow.
mo is offline
Old 05-09-2003, 01:57 PM
  #1194
utieh's Avatar
thanks, so i will use silver in the front during I wait for the green .
utieh is offline
Old 05-09-2003, 02:13 PM
  #1195
rc-zombies's Avatar
Default Spring Rates:
Part Number Colour Spring Rate lbs/inch
YS-1360 Black 9.67
YS-1355 Blue 10.45
YS-1465 White 11.01
YS-1460 Hot Yellow 12.85
YS-14525 Stainless 12.89
YS-14575 Hot Pink 13.09
YS-1455 Hot Green 13.75
YS-1560 Dark Green 16.21
YS-1450 Hot Orange 17.68
Usualbe TC3 springs:
Associated TC3 Green 12.00
Associated TC3 Silver 14.50 Same as Rayspeed Silver
Associated TC3 Blue 17.00 Same as Rayspeed Blue
Associated TC3 Gold 19.50
Anti Roll Bar chart:
Colour Torsion Rate (N/rad) Equivalent rate at wishbone(lbs/inch)
Black 24.57 9.1
Silver 30.57 11.4
Brass 38.34 14.2
Copper 40.77 15.1
Old 05-09-2003, 02:23 PM
  #1196
Matt Howard's Avatar
speedtechrc- the yokomo Ti screw set retails for $37 and my local hobby shop that we can't say anymore has them in stock. Yes they are very low on the price of the screw set but for some reason 2 Ti ball studs will set you back $17!
Matt Howard is offline
Old 05-09-2003, 02:54 PM
  #1197
sosidge's Avatar
Default Re: Spring Rates:
YS-1360 Black 9.67
YS-1355 Blue 10.45
YS-1465 White 11.01
Where did you find those figures rcz? My understanding is slightly different...
Yokomo springs are graded thus... First two figures are spring wire diameter, latter figures are number of coils - so YS-1460 is a 1.4mm, 6 coil spring.
Thicker wire = stiffer spring
Fewer coils = stiffer spring
So the order "should" be (in the YS-14 range) White, Yellow, Pink, Green, Stainless, Orange (this is the order Yokomo rate them, except the stainless which isn't listed in the chart you get with a pair of springs). Because of variances in manufacture, you can end up with values like those above if you measure springs individually though.
I believe Yokomo rate the 1355 Blue as stiffer than the 1465 White, but softer than the others. Not sure where they rate the 1560 GT4 spring.
Usable TC3 springs:
For those that didn't know, the TC3 springs are a narrower diameter (will they rub the threaded bodies?), and use differently dimensioned shock bottoms.
Black 24.57 9.1
Silver 30.57 11.4
Brass 38.34 14.2
Copper 40.77 15.1
Wondering where you found these figures as well? I thought there was only three grades of Yokomo anti-roll bar, black (1mm), silver (1.2mm), gold (1.4mm).
sosidge is offline
Old 05-09-2003, 03:03 PM
  #1198
rc-zombies's Avatar
Sosidge..
Forgot where I down loaded those numbers from. I'm sure someone took the time who had a measure device of some kind to measure the springs. Yes it is true what you have stated:
With the right instruments it can be measured lbs/inch or even gr/mm for those metric folks
TC3 springs are only a fraction smaller in diameter. Some racer use TC3 shock parts on their TC's
As for the anti-roll bars...
The SD kit comes with 4...as shown:
Old 05-09-2003, 03:04 PM
  #1199
noline's Avatar
I have MR-4TC-SD with a 48 pitch 70 tooth spur, what pinion shoud I use For a Trinity Monster Horse power stock motor I race on an med/large sized track any help would be greatly appreciated
noline is offline
Old 05-09-2003, 03:06 PM
  #1200
rc-zombies's Avatar
Yokomo recommended gearing a P2k at 6.4-6.8
for the Monster maybe around 7.2 final drive ratio to start.
