Yokomo MR-4TC SD
I've run the tobee main shaft in my mod car with no problems. How did you break a rear shock tower?
Shookie:
That must hurts~~~ Did somebody step on your car?? because that happen to me the other day.
now i have 1 front shock and a top deck to replace for my silver SD...
my drivetrain also binds up now.... more parts to buy
Tobee center is not bad as i run mods for fun, they don't break like a graphite one(duh!)
but they do bend when you crash full speed right into the wall(Yes, i have done it)
and i have finally finish setting up the servo in the Rayspeed chassi..
took me like 1 hours to do it.... i just sand the servo case a little and that fixed the problem...
i really don't want to sand it down.. but i was too tired... so i gave up~~
Originally posted by Mr. Shookie
Snapped my first drive shaft yesterday at Hot Rods, Man I hit the wall at full throttle, and the battery came loose hit the shaft and can you say bye bye to a 22.00 grafite shaft........OUCH that is two big Breaks in less than one week. I need to take a break from breaking LOL. I just replaced a Rayspeed rear shock tower the day before.....SHEEEEEEEEESH enough all ready. Sorry Guys had to vent a little. Also should I go and get another grafite or should I risk the Tobee lightwieght?
Thanks,
Stephen <><
Thanks,
Stephen <><
Anybody know anything current on the new Rayspeed 2 chassis?
- jaybee
- jaybee
Talked to Stev @ Speedtec and it seems that Yokomo busy trying to get out the new Worlds kit but the new Rayspeed should be out right behind the worlds kits.
Stephen <><
Stephen <><
how much different between the ssg kit and the cgm?
Stephen <><
Stephen <><
- jaybee
because your questiion is far too broad.
ooooh.to make it simpler,which is better?
ntc3freak:
the fact that the CGM is less prone to tweak is very important.
just to illustrate:
In PJ where we both live, almost every single car is a CGM. Most of the drivers drove the SSG but I guess we all agree that the CGM is better. THe only weakness is weight and it's a costly affair to fix that weakness.
just to illustrate:
From the couldn't help it department......
Originally posted by lee82gx
ntc3freak:
just to illustrate:
ntc3freak:
just to illustrate:
*sighs* it really was a pain having to put the lead in you know. :P
Originally posted by Tek Nickal
If your trying to save some money, some places are selling the SGG for $200 only. Where as the CGM is still at the same price.
Hey Matt,
any developments on those new RS CVD's?
