Team Associated B6 & B6D thread >
Like Tree649Likes
    Hide Wikipost
Old 06-07-2017, 10:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Team Associated B6 & B6D thread
Last edit by: RCBuddha
Welcome to the B6 Wiki!
Quick links to all the sections on the first page!
Frequently asked questions - the most common questions you may have answered here!
Aftermarket Parts - parts for the B6 and B6D
Tech Tutorials- tuning guides, ball diff and shock building videos and tutorials
How to's and build-specific posts
Team Associated Laydown transmission conversion for B6D:
Laydown conversion
Instruction Manuals:
B6: B6 Manual and setup sheets
B6D: B6D Manual and setup sheets
How to Sand and Seal carbon fiber:
Sanding and sealing carbon fiber
Sanding and sealing carbon fiber 2
Sanding and sealing carbon fiber 3
Sanding and sealing carbon fiber 4
Charts for Quick reference:
1) put inner bearing in hub
2) slide large shim over axle all the way up to the back of the axle
3) slide axle/bone into hub carrier
4) slide small shim onto axle through hub carrier
5) push outter bearing into hub carrier
using that i'm able to put my normal male silverback gorilla wheel nut tightening job and there's no binding. in the pictures that come with the shims (the pic socket posted) it seems like they want you to slide both shims onto the axle before sliding the axle into the hub carrier and like i said, that doesn't work.
I've traditionally done the diff screw head on the left side (driver's side), but have since switched to the Right side (passenger side) regardless of transmission type (3 gear RM vs 3 gear MM and 4 gear MM).
Kdub (Kurt Wenger, former AE designer) had this to say on the matter:
Originally Posted by kdub
I think I count as an authority on the matter. I always run my diff screw on the right side (when sitting "inside" the car). I take off the tire and pull the outer hinge pin to get to the adjustment screw.
The right rear is the way the AE manuals state (or used to state). It really shouldn't matter since you go around turns both left and right.
B6D 3-gear:
Print Wikipost
Old 05-30-2017, 09:43 AM
  #6676
fast-ho-cars's Avatar
we have had five racers (one being me) at our track break them, with aluminum shock towers two, with stock towers three. mine broke from a car landing into my B6. the gear boxes break in the shock tower mount area where the walls are under 1.5mm thin.
they are not breaking on the scale that B64 drivers are experiencing. but the early B6 cases seemed less dense, aerated, and more fibrous due to less binding material, not sure if there has been a running change?
it's luck of the draw, we have a AE team driver at our track who was running Mod, he clipped a dot, car went airborne, flew 20++ feet, over a 6 foot wall and landed upside down on a side walk next to a 4 lane street and was fine.
fast-ho-cars is offline
Old 05-30-2017, 02:06 PM
  #6677
I Know this is going to be a loaded question so I appoligize in advance...
I built my buggy to go in mod class at my local club track primarily. The track is small/med in size. The track surface a primarily hard packed. Conditions usually start on race day with a bit of dampness and loose sand on top. We blow it off but it can be a bit loose early on. By the second qual round and good sun...traction come up and a groove builds. Hole Shots seems to be the most consistent throughout track changes. However, when the groove come in nicely, we can/do run a dirt web/bar code style tire.
My buggy is the B6d. It is currently in its stock setup. Others at my track, run a 6.5t to 7.5t motor. I am looking for recommendations for a motor brand, make, size for this application. Like many, I am looking for the most power for the money. Initially, I had heard great things about the Maclan MMR in either 6.5 or 7.5 size.
Thoughts on all the above?
freezeframe007 is offline
Old 05-30-2017, 02:30 PM
  #6678
Default which servo should i choose
i recently bought a used b6, it come with a futaba bls451, but i end up break the servo, i am looking to buy a new servo, should i buy another bls451 or savox 1258? savox have better spec and cheaper than futaba
james101291 is offline
Old 05-30-2017, 02:31 PM
  #6679
mellow's Avatar
Trader Rating: 24 (100%+)
Go with a Savox. Great value
mellow is offline
Old 05-30-2017, 02:44 PM
  #6680
DRJVogel's Avatar
Yeah, +1 on Savox.
DRJVogel is offline
Old 05-30-2017, 03:15 PM
  #6681
Savox are good, but I'd use the 1257 for the B6. The 1258 has higher torque numbers, better suited to the T5M or SC5M. The 1257 has more speed. Just my opinion. Most mere mortals can't tell the difference but if you're into numbers, well..
bds81175 likes this.
BruceR. is offline
Old 05-30-2017, 04:30 PM
  #6682
I've got savox in all my junk right now and no complaints other than the noise. I would likely go with something like an xpert 3402 in my buggies if I ever feel the need for a change.
Rebuke is offline
Old 05-31-2017, 01:45 AM
  #6683
ray_munday's Avatar
Hi mate, these conditions are similar to what we run down here in Australia. On an outdoor track I would usually recommend less power than 7.5T in 2wd. 8.5T is fine for most conditions, 7.5t can give you a little more punch to clear big jumps but needs a good throttle finger. 6.5T can feel fast but lap times are usually slower as the car has too much wheelspin.
As for brand, that is definitely personal preference and you will get lots of answers. I use the Reedy Mach 3 motors, they have a very smooth powerband at lower RPM which is very important for 2wd, as well as great top end.
If you are interested, this is a setup guide I put together for racing in similar conditions down here. Hope its useful.
http://www.rctech.net/forum/attachme...y-m-201612.pdf
Ray
eper, bds81175 and freezeframe007 like this.
ray_munday is offline
Old 05-31-2017, 03:40 PM
  #6684
I hear everyone talking about how light the car is. I am guessing there is very little difference between the B6d and B6 in weight with all other things the same (electronics, battery, etc.)? I keep reading how people are adding weight to get their car to meet the minimum 1499g limit? I am having a problem digesting this...lol. I built my B6d for mod. I have built it completely box stock except I put Losi white springs on the rear and AE grn springs on the front. At this point, I am at 1574g with no aftermarket parts. I do have a set of 60mm wheels/tires on when I put it on the scale. I guess those could be worth a few extra grams. But, I would definitely not be needing to add weight to make the minimum. Does this 1575g sound right? I know a justock esc probably weighs in at less than my xr10 pro 160a. I just don't see how these things could add up to the numbers I hear people talking about...
Old 05-31-2017, 04:29 PM
  #6685
Trader Rating: 19 (100%+)
I run a car set up for 17.5. No slipper, mip pucks, titanium screws, short servo, etc. That gets the weight really low.for mod, I've seen most run around the 1550 gram range.
Chris Brown is offline
Old 05-31-2017, 04:54 PM
  #6686
tsair's Avatar
Wheels and tires are probably close to 100g, so your buggy is going to be pretty heavy. Take a picture, are you running a square pack or something? Or a lot of brass?
tsair is offline
Old 05-31-2017, 06:01 PM
  #6687
I have a b6 with both alloy chassis plates, brass c & d blocks,36 gr battery weight, prime slicks, and thin shorty battery and weigh 1530 gr. Also exoteck top shaft and slipper elimanator. smc esc, 17.5 orion motor, spectrum 6040 servo
sgtlt is offline
Old 05-31-2017, 08:52 PM
  #6688
my b6d mod buggy is 1540g with a 220g battery right off the track with a lite weight body and a pretty heavy Maclan esc/wires.
Rebuke is offline
Old 06-01-2017, 12:57 AM
  #6689
battery. wheels and tires. i found for instance that the jconcepts pindowns were significantly heavier than schumacher minipins.
Lunchie is offline
Old 06-01-2017, 06:22 AM
  #6690
eper's Avatar
Trader Rating: 14 (100%+)
Anyone else running this third hole on the rear arms? And if so can u give me a idea what u felt positive or negative effects. I know what it's supposed to do just want opinion on the feel of it. Thanks guys
eper is offline
