TLR 22 3.0 Race Kit Thread! >
Like Tree26Likes
    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Old 05-16-2016, 12:30 PM
  #2851
LT
LT's Avatar
Arrow pointing up=higher roll center=more chassis roll.
Arrow pointing down= lower roll center=less chassis roll.
Is this correct Frank?
LT is offline
Old 05-16-2016, 12:33 PM
  #2852
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I assume you are talking about the anti-squat pills? They always point up.
Frank Root is offline
Old 05-16-2016, 12:35 PM
  #2853
LT
LT's Avatar
I was talking about the plastic insert in the rear inner ball stud mount.
LT is offline
Old 05-16-2016, 12:40 PM
  #2854
TLRacing
Frank Root's Avatar
The camber gain is more important on most tracks than the roll center, IMO. More camber gain (1 down), will roll more, and often have more side bite, and more rear grip on throttle while still cornering. Less camber gain (1 up), will roll less, have less rear side bite, and have more grip on throttle once the car is straight/squared up.
Old 05-16-2016, 12:51 PM
  #2855
LT
LT's Avatar
My understanding has always been ball stud height effects roll center and camber link length effects camber gain. Is this not correct? Never want to miss an opportunity to learn.
LT is offline
Old 05-16-2016, 01:00 PM
  #2856
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
What I am reading is you should take some time out and test the different settings on the track and experience it for yourself if you can.
Kraig is offline
Old 05-16-2016, 01:09 PM
  #2857
TLRacing
Frank Root's Avatar
Moving the ball stud height affects roll center and camber gain. Camber links affect both too, but the roll center to a smaller degree.
  #2858
LT
LT's Avatar
EFFECTS OF REAR ROLL CENTER ADJUSTMENT
REAR ROLL CENTER CHARACTERISTICS
Higher
• Increases on-power traction
• Use to avoid traction rolling at corner entry
• Use under low-traction conditions
Lower
• Decreases rear traction into corner
• Increases steering into corner
• Use to avoid traction rolling mid-corner and corner exit
REAR UPPER CAMBER LINK -
LENGTH
CHARACTERISTICS
Shorter link (outer hole on tower and/
or inner hole on hub)
• Increases steering and decreases
stability into corner
• Increases on-power traction slightly
Longer link (inner hole on tower and/or
outer hole on hub)
• Decreases rear camber gain
• Increases stability
• Slows down the car‘s responsiveness
SHOCKTOWER
EFFECT ON REAR ROLL CENTER
This has always been my bible on the subject and has always felt spot on as far as what the changes have felt like for me. My interpretation of the above post have me re thinking it. I just want to know if it is wrong.
LT is offline
Old 05-17-2016, 09:38 AM
  #2859
MNiceGuy's Avatar
Will there ever be a standard-thickness body compatible with the new laydown transmission?
While I understand it's rather counter-productive to drop the COG and then add weight to the body but, at least for practice, I'm looking for something with a higher durability factor.
MNiceGuy is offline
Old 05-17-2016, 09:50 AM
  #2860
K_King's Avatar
Trader Rating: 47 (100%+)
You can run the standard body on it. You just won't have a covered spur.
K_King is offline
Old 05-17-2016, 10:12 AM
  #2861
MNiceGuy's Avatar
Is there a good way to cover it in that case? Personally I'm fine with it but the local track owner is not.
MNiceGuy is offline
Old 05-17-2016, 10:31 AM
  #2862
K_King's Avatar
Cover it with extra lexan I suppose. It can be done.
K_King is offline
Old 05-17-2016, 10:34 AM
  #2863
gokarter64's Avatar
Use the yokomo yz2 body. It fits quite nicely on the 3.0 i use it on my car, small gaps near the front but if your using the laydown then it wont really matter as clay tracks dont kick up much if any dirt.
gokarter64 is offline
Old 05-17-2016, 10:37 AM
  #2864
Matt Trimmings's Avatar
Trader Rating: 170 (100%+)
Honestly, the body is pretty well protected by being so low. The shock towers / wing are going to take the brunt of any impacts. Just don't rip it off when taking the body off the chassis.
Matt Trimmings is offline
Old 05-17-2016, 10:50 AM
  #2865
K_King's Avatar
These are what I've gone off for roll center.
https://youtu.be/Wl1qcwe_ATU
https://youtu.be/tWdRQaz_Xq8
K_King is offline
