TLR 22 3.0 Race Kit Thread!
#2101
I've thought about trying the Serpent gear diff, but do so far I've not had problems with the Losi one when using Kyosho o-rings. The stock black rings in the Losi kit will leak, but the Kyosho ones are fine so far. I've also started adding some green slime on them for good measure.
#2102
FEW IMPORTANT QUESTIONS BEFORE ORDERING
1. Has TLR released updated rear hinge pin holder and camber blocks yet? I heard the original ones were breaking? If so how can I tell which version kit is which? Will hobby shops have the updated kit if available? Or will TLR replace with the updated parts if contacted?
#2103
Dropped in the Serpent SRX4 gear diff last night. It seems like a very high-quality unit and went together without any drama. Very smooth operation.
I used 3 10x12x0.2 shims on each side and it fit in the TLR case very nicely.
Another thank you for those who offered up their wisdom on the topic. I can't wait to run it tonight!
#2104
A friend of mine just picked up a 3.0 last week and it came with the updated pivot block.
2. I saw Dustin Evans had an "astro" edition where the motor/tranny was mounted lower and more forward. Will this be available to the public? I plan on running my car mostly on carpet/astro. Is the 3.0 a good car for this? I already have a 22SCT 2.0, so it makes sense to get the 3.0, but not if its not running well on carpet.
I think the car is great on carpet. Compared to a friend's B5M, the 3.0 is faster while being more controllable and consistent. This is not factoring set up obviously.
Personally, I like the TLR because I think it a better-built car. I have a couple AE 5-series and there is a clear quality (and in some cases quality control) difference.
#2105
While waiting for the good CF panel to arrive, I tweaked the design of my chassis. All of the little issues in my g10 prototype have been fixed. I'm confident saying this is the final iteration of the design!
The new panel of CF showed up this week. The 2.5mm panel has a 3k plain weave outer layer on top of a quasi-isotropic uni-directional core. Good stuff for sure! It's so stiff I don't even need the upper side braces.
Upper side braces I'll probably never use. Certainly I over designed it the first time.
#2106
#2107
They break.....4 so far at my local track. It happens with every car on the first run. Team driver's don't wreck as much as regular guys Losi recognized it and addressed the problem. The only issue is if you mail order the part there's no way of knowing if you will get a new or old part.
#2108
Your 4 broken ones may be 1/2 of all the incidents I've read about. There are at least 12 of these running regularly at my local track, a couple of them by sportsman drivers under the age of 10. The problem isn't the part, it may be the track (super-gigantic jump?).
#2109
CAMBER LINk
#2110
Just got my TLR 22 3.0 finished and am looking forward to testing it....
#2112
#2114
Got a question guys. I recently completed my buggy and I am new to the buggy racing scene. At our local track which is hard packed high bite the car handles fantastic box stock on 98% of the track. There is a long straight with a decent sweeper going into a 180 at the end that I'm having traction issues with. On power or off it's giving me issues. Should I just deal with it or sacrifice some handling overall to get the best average performance out of the car. And if I should change anything where should I start? Stiffer springs or thicker fluid in the front? I've moved the battery all over doesn't seem to make a difference.
#2115
It took me a few broken front spindles for me to find the right line. I also found it really helpful for me to turn down my drag brake (from 17% to 5%). This allowed me to lift off the throttle and carry more speed while rolling faster through the sweeper and keeping more speed. My speed naturally scrubs itself as the sweeper becomes a decreasing radius turn.
