TLR 22 3.0 Race Kit Thread!
#2251
Thanks for the help guys does a 17.5t motor helps in clearing the jump easily?
Also a recommended Gera ratio for 17.5t motor
Thanks in advance
Thanks in advance
#2253
I'm racing the car weekly on astroturf and the car is now as good as my Yokomo was. It didn't take much to fit the tranny in, I've made 2 adapter plate , added some meet to the case (Plast-aid) to drill new hole and drilled two hole in the chassis. No issue so far and the Yokomo gear diff is very good! SO its good enough until TLR release one
I should have sanded the tranny once the plast-aid was applied but I just wanted to test if it was holding first and kept it that way.
#2254
Venom 2S LiPo 25C Hardcase Battery Pack w/Universal Connector (7.4V/5000mAh) will this fit in the losi 22 3.0? thanks
#2256
thanks will this Schumacher Racing "Mini Pin Slim" Premounted 2.2" 1/10 2WD Buggy Front Tires (2) (White) (No Hex) fit the front?
#2257
Here some detail
I'm racing the car weekly on astroturf and the car is now as good as my Yokomo was. It didn't take much to fit the tranny in, I've made 2 adapter plate , added some meet to the case to drill new hole and drilled two hole in the chassis. No issue so far and the Yokomo gear diff is very good! SO its good enough until TLR release one
Pics aren't working.
#2258
Here some detail
#2261
Do you have to run a shorty servo or is that just a personal preference? Or how much room is there if you run a standard one.
#2262
#2263
Here some detail
Wow. The internet is a scary place.
#2264
