TLR 22 3.0 Race Kit Thread! >
Like Tree26Likes
    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Old 03-01-2016, 06:26 PM
  #2236
Trader Rating: 8 (90%+)
Originally Posted by dirtracer4
What is the benefit of using the YZ2 trans?
People have been asking for a laid down transmission for carpet and astro applications and there are no news from TLR yet, so i am guessing this is this one individuals answer to it until TLR produces one for the general public. Why he chose YZ2 could be bcause it might be the only one that fits with minimal modifications.
juicy74 is offline
Old 03-01-2016, 06:44 PM
  #2237
Trader Rating: 15 (100%+)
Originally Posted by SCRAFAN
Still missing the dust cover on the outer LF camber link.
You little bugger 😵 Pick the one flaw out haha. But I know I realized half way through I had them and put some in but didn't feel like breaking the thread lock to do the rest
lyons238 is offline
Old 03-01-2016, 07:13 PM
  #2238
Does anybody have any tips on getting the slipper adjusted close on the first try? It's gonna be with a 17.5 motor setup for a high bite clay indoor track
mserno75 is offline
Old 03-01-2016, 07:41 PM
  #2239
Davidka's Avatar
Trader Rating: 86 (100%+)
Make sure the diff is tightened per the assembly instructions, then set the slipper tight enough that it's hard to turn with your right thumb while holding the wheels stationary. Put a fully charged battery in, hold the wheels down on the table and give it a burst at full throttle. The slipper should slip easily. Tighten the nut 1/2 turn at a time while repeating the full throttle jab. You want the slipper to slip while the front of the car rides off of the table and the diff should NOT slip. This setting will protect the diff, while giving you max drive. You should not need to mess with it again unless you want to run it looser as a tuning option.
Davidka is offline
Old 03-01-2016, 07:46 PM
  #2240
SCRAFAN's Avatar
Trader Rating: 22 (100%+)
17.5??? Tighten all the way and punch it!!
SCRAFAN is offline
Old 03-02-2016, 10:28 AM
  #2241
68pontiac's Avatar
I don't personally run 17.5 but I know that a large majority of people that do run stock either run the slipper locked or completely eliminate it altogether. If you have the traction available I don't see why you wouldn't just run it locked.
68pontiac is offline
Old 03-02-2016, 11:21 AM
  #2242
Can anyone help me with a motor esc combo for the kit and also the servo???
My budget for motor and esc 250 dollars
Thanks in advance
stashy77 is offline
Old 03-02-2016, 12:22 PM
  #2243
Trader Rating: 23 (100%+)
Thanks in advance
Orion R10 Stock $142
http://www.horizonhobby.com/cars-and...3s%29-ori65120
The Trinity Line of motors are less than $100
http://www.horizonhobby.com/cars-and...5-trirev1802bs
Nice little shorty servo $75
http://www.horizonhobby.com/product/...vo-p-spmss6240
electrickid is offline
Old 03-02-2016, 01:26 PM
  #2244
68pontiac's Avatar
Thanks in advance
The SMC RF-120 (or 160) is a fantastic ESC and you can get it in combo with their new mod motors for $125
SMC also sells excellent shorty packs that are always recommended here for $33 apiece.
I run Spektrum S6040 servos (now discontinued) in all my 1/10 stuff and I've found several of them here in the for-sale section for ~$45-50.
Everybody has their own preferences and recommendations but I've always had good luck with Spektrum, Airtronics, Novak, Trinity, and SMC gear.
Old 03-02-2016, 01:33 PM
  #2245
BRSracing's Avatar
Trader Rating: 67 (100%+)
Hold the rear wheels stationary and spin the spur by hand. Tighten the slipper until the spur is hard to turn. that will get you close. to fine tune it put the car down on the track and go full throttle and listen for it to slip. should slip for about a foot or so. for stock some use eliminator or tighten it down all the way, did not like that setup myself. Holding the rear wheels and giving the throttle full pull to lift the front wheels is not a good way to check stock motors. stock motors don't really have the punch to use the front wheel pull off the ground test.
BRSracing is offline
Old 03-02-2016, 01:38 PM
  #2246
BRSracing's Avatar
Thanks in advance
the orion stock esc and hobbywing stock esc are good, around 130.00. i think you can go down to a 5.5 motor. I have used both with no issue.
motors are all pretty close in price. I have liked Tekin, Reedy, and Schuur speed for motors. Savox 1258 servo is about 60. lots of times you can find a good price for a gently used servo
Old 03-02-2016, 01:52 PM
  #2247
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
Thanks in advance
You can't beat the Orion ESC's for reliability and performance (feel).
Frank Root is offline
Old 03-02-2016, 01:56 PM
  #2248
Suspended
Trader Rating: 61 (100%+)
Originally Posted by Wildcat1971
Imo, dual rates work better, as you keep your entire trigger pull. EPA just limited the max top speed, but the last little bit of trigger pull will do nothing. D/R will also soften up the bottom end and make a hot motor easier to drive. That has been my experience with radio tuning.
Not sure if serious or trolling.
PRetty sure there's some sarcasm in your reply?
Socket is offline
Old 03-02-2016, 02:57 PM
  #2249
gokarter64's Avatar
Thanks in advance
LRP flow with a viper black edition motor, top level stuff and within your budget. Amain hobbys has them on sale
gokarter64 is offline
Old 03-02-2016, 05:06 PM
  #2250
G_WORD's Avatar
Trader Rating: 124 (100%+)
gear ratio help for a 17.5
G_WORD is offline
