TLR 22 3.0 Race Kit Thread!
#3211
Just getting back into RC racing after over 20 years away. Got my 22 3.0 put together with a Reedy Mach 17.5 motor for stock racing.
I installed the 70t spur (part #TLR3978) with two slipper pads (part #LOSA3123) in place of the new spur and slipper pads but I can't get the slipper tight enough to raise the front end like I see in all the videos on building the diff and slipper.
I tried to stretch out the spring and even post a washer in between the spring and the slipper plate in hopes of getting it tight enough, but no go. I tried to stretch the spring slightly and even when bottomed out I get it slipping and it won't raise the front end up.
Any suggestions?
Any suggestions?
#3212
R/C Tech Elite Member
Any suggestions?
Any suggestions?
#3213
You should only set slipper by that method with a mod motor.
#3214
Seems like there are a lot of chassis and transmission options available now. It would be really handy if someone could put together a chart with all the various chassis and diff combinations with part numbers and the types of tracks to use them on. Maybe something Frank could cover in his next Facebook live stream.
#3216
Any suggestions?
Any suggestions?
It's an experience thing, but you can hear how hard the motor works to make the slipper slip, and this lets me know when it's tight enough. You'll have no issues with a slipper eliminator though, like TLR332056
#3218
The stock motors don't have enough power to lift the front wheels regardless of the slipper setting, so you don't want to try and set your slipper that way.
#3219
#3221
The dirt laydown has personally for me been my favorite. It lowers the diff height back down to standard height which allows for the standard rear hub, but also to use the standard front LRC pivot. I felt the car rolled through the corner better, jumped better, and was a little less edgy on dirt. Overall both are great options and offer several options for a variety of tracks.
#3222
Frank, could you share what type of cars that the team was running at hotrod shootout. I saw on fb that Ryan had a standard car and Dustin had had a laydown?
#3224
Yes, you are correct. The laydown chassis conversion comes with the +3.5mm gear case, and the dirt laydown is bought separately.
