TLR 22 3.0 Race Kit Thread!
#1711
Got the thumb screws for the battery hold down, I highly recommend this change. Much cleaner and easier to use, at least for me.
#1713
would you mind sharing your prep technique and motor size?
I remove the foam inserts then turn the tires inside out and spray enough Simple Green to completely degrease the mold release agent from the tires and spend extra attention on the bead area pinching the bead with my fingers as I rotate the full circumference of the bead. Then I rinse with water and lightly dab the foam insert (to remove the chalky residue) with the paper towel that I used to dry my hands after rinsing the tires.
To prep the wheels, I'll use a rubbing alcohol swab to degrease the bead of each wheel, usually 1 swab will cover all 4 wheels.
I use AKA glue and carefully lift the bead up so enough glue completely seats to the inner lip of the wheel as I apply the glue to the wheel and then let the rubber press onto the bead of the wheel.
After setting all 4 tires with CA, I'll go back and spot check for any holes by slightly pulling back the rubber to expose any weak areas and fill the voids with a drop or two where necessary.
I've mounted the tires within 2 hours of racing on a cool day with ambient temps around 66° and running a 17.5T motor. The traction is very high at Thornhill Jr, so the tires usually go bald after 4-5 heats of racing. It's possible that I don't get enough runs to see the beads peeling off because I go through tires so quickly?
I raced at OCRC a few weeks back and couldn't help but to notice how little tire wear they've got going with their mister system. I'd be curious to learn about how many heats of racing before the peeling starts to occur for you as well?
TIA
TIA
#1714
I do pretty much the same prep as you except I also use the simple green on the rims. I haven't done anything to the inserts as I didn't think they really interfered with the gluing process. The local nitro guys use the same method and none of the 8th scale tires have this peeling. I have some AKA's glued on some Losi rims currently so we'll see how they turnout.
#1717
Hey Frank, Great showing today at the Reedy race!
15th seed in 2wd and top ten in 4wd. WTFG!
Best of luck to you and Ryan this weekend.
#1720
i stripped a screw and broke my rear shock tower, but it seems to be out of stock everywhere. anyone know where i can find one
#1721
Deleted
#1722
You're getting worked up over nothing. The plastic hexes work perfectly and don't need to be changed. This is why it was barely discussed at all...
#1723
hi
im building this 3.0 with my 8yr old, both of us having a great time so far.
opened the bag for the rear suspension and saw the plastic wheel hexes.. i threw up in my mouth a little bit.
im sure this was already discussed ad nauseum (pun intended).. but how many pennies saved with this move?
im fine with buying upgrades... but why even bother with this piece of plastic in the box?
give me a non threaded aluminum hex and let me buy the threaded piece in a race or two. (ala scte)
im embarrassed to put this plastic piece on.
i guess i should have known to pick this up before i started the build.
sorry for the rant.
K
sorry for the rant.
K
Easy 'fix' if you really 'need' them . . .
#1724
kkiooo, I am with you on this. I hate plastic hex's have changed them on all my cars. Went with the + .75 tlr option hex's on this car. Wanted to widen the rear just a little.
#1725
Anyone run the 3.0 on carpet? Thoughts?
