TLR 22 3.0 Race Kit Thread! >
Like Tree26Likes
    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Old 01-21-2016, 05:49 AM
  #1696
RC10Nick's Avatar
Originally Posted by HollywoodRC
Ok, I have searched this entire site trying to figure out what wheels and tires go together. Grrrrrrrrrrr. 2.2, 2.4 60mm, 61mm. I like DE Racing, AKA, and Pro-Line wheels. Do they make wheels for the 3.0. I know they made them for the 2.0, but I'm having trouble finding them for the 3.0. Anyone know the part numbers for any of these? Last, what tires go with this wheels? I feel like such an idiot.
2.2 tires go with 2.2 wheels.
2.4, 60mm, 61mm, and VTR are all the same thing and will all work with each other.
Losi makes wheels with the correct offsets for the 3.0, so I would just stick with losi wheels.
RC10Nick is offline
Old 01-21-2016, 06:01 AM
  #1697
Andrew Gray's Avatar
Ok, for the time being only TLR makes front wheels that will fit the new 3.0 12mm front hex. The rear wheels are for the 3.0 are unchanged/same as the 1.0/2.0 buggy.
I'm know it's been stated 100 times on this thread, but just for further clarification; NO other 12mm hex front wheels(AE/KYO) will fit the 3.0.
I'm sure that in the near future Proline, AKA, & JConcepts will make a new front wheel to fit the 3.0 12mm front hex.
2.2" tires go on 2.2" wheels & 2.4"/60mm/61mm/VTR/EVO wheels go with 2.4"/60mm/61mm/VTR/EVO tires
The TLR part #'s for the wheels are:
2.2":
Front White: TLR43009
Front Yellow: TLR43010
Rear White: TLR7100
Rear Yellow: TLR7101
Front White: TLR43011
Front Yellow: TLR43012
Rear White: TLR43015
Rear Yellow: TLR43016
Andrew Gray is offline
Old 01-21-2016, 08:22 AM
  #1698
Has anyone run the 2.4 wheels all around and what was your opinion on them?? Would the 2.4 be a better bet on indoor high bite clay?? Lower profile tire=less side wall roll and less grip?? Im finding the car to bicycle on high speed sweeping corners.
Gromy82 is offline
Old 01-21-2016, 09:05 AM
  #1699
ryan432greening's Avatar
Is this the gear diff kit I need for the 22 3.0?
Gear Differential, Complete: 22RTR, 22SCT (LOSA2954)
ryan432greening is offline
Old 01-21-2016, 09:18 AM
  #1700
LOSA2930
http://www.horizonhobby.com/diff-set...--scb-losa2930
No you need LOSA2954
http://www.horizonhobby.com/gear-dif...22sct-losa2954
R/C Rich is offline
Old 01-21-2016, 09:28 AM
  #1701
Originally Posted by R/C Rich
Thanks, I must have been editing my post when you replied. Appreciate the time!
Old 01-21-2016, 10:35 AM
  #1702
Trader Rating: 33 (97%+)
I've been having better luck with the 61mm wheels from TLR and ProLine Electrons MC for high traction indoor clay. I've experimented with the 2.2" wheels and same Electron MC tire, but my lap times were a little better with the 61mm TLR wheels all around.
I've also tried some rear DE Racing wheels for the RB6 which supposedly have the same offset on the rear, but it was necessary to install a spacer on the wheel to properly secure the lock nut. Those wheels perform a little worse (for me) than the 2.2" stock wheels that came with the kit.
I've heard that ProLine has discontinued making 2.4" tires... speculation has it that the tires are peeling off the wheels too easily in the mod classes. I'm running stock and haven't had any tires peel off my 61mm wheels yet. I've been stock piling on as many 2.4" Electron (MC) tires I can get my hands on... It's gonna suck when I have to switch back to 2.2" unless ProLine reconsiders making another batch of 2.4" tires later.
I plan to experiment with some 2.4" tires from JConcepts and AKA tires soon as I hunt for a suitable replacement for the 2.4" Electron (MC).
billdelong is offline
Old 01-21-2016, 11:10 AM
  #1703
rcus3r's Avatar
Not sure why they would be peeling off. 1/8 buggy uses the same style wheel, and I never had a problem with those.
I do see the VTR Electrons MC have been discontinued on proline's site. amain still has them in stock...
I plan to experiment with some JConcepts and AKA tires soon as I hunt for a suitable replacement for the 2.4" Electron (MC).
rcus3r is offline
Old 01-21-2016, 12:09 PM
  #1704
HollywoodRC's Avatar
2.2":
Rear White: TLR7100
Thanks Andrew, That makes it so much easier. I do like the L shape beads on the VTR and EVO tires and wheels. I also have the Concepts 10mm front hexes so I can run my old wheels and tires if I need to.
Again, thanks for all your help
HollywoodRC is offline
Old 01-21-2016, 02:36 PM
  #1705
Davidka's Avatar
Trader Rating: 86 (100%+)
I find it's dependent on how fresh the glue used to attach the tires was. I used to see 1/8 tires come un-glued all the time, including my own if I didn't use fresh glue to attach them.
Davidka is offline
Old 01-21-2016, 03:21 PM
  #1706
STLNLST's Avatar
Trader Rating: 32 (100%+)
I've had the peeling off on Proline, and AKA tires. Can't be prep or glue as non of my 2.2 tires experienced this. Maybe its the rims. My 2.2 were all AE rims and 2.4 was AKA and Proline. I have Losi rims in both sizes now so we'll see if I can keep the tire's on the rim
STLNLST is offline
Old 01-21-2016, 03:24 PM
  #1707
STLNLST's Avatar
Hey Clint, I don't think they sell just the bones, but # TLR332002 is the complete aluminum driveshaft set.
I see that so I will get the MIP one's instead. I'd like to be able to purchase just the bone if it should happen to get bent. Thanks for the help. Glad to see you're still around. Some of these younger cats probably do know who Andrew Gray is
STLNLST is offline
Old 01-21-2016, 03:25 PM
  #1708
skrichter's Avatar
Apparently Maifield thinks the chassis flexes too much.
http://events.redrc.net/2016/01/chas...n-maifield-11/
skrichter is offline
Old 01-21-2016, 03:27 PM
  #1709
Jorgen's Avatar
Image is broken, probably direct link protection by the web server; I think the article you got it from is this?
Jorgen is offline
Old 01-21-2016, 04:47 PM
  #1710
would you mind sharing your prep technique and motor size?
I remove the foam inserts then turn the tires inside out and spray enough Simple Green to completely degrease the mold release agent from the tires and spend extra attention on the bead area pinching the bead with my fingers as I rotate the full circumference of the bead. Then I rinse with water and lightly dab the foam insert (to remove the chalky residue) with the paper towel that I used to dry my hands after rinsing the tires.
To prep the wheels, I'll use a rubbing alcohol swab to degrease the bead of each wheel, usually 1 swab will cover all 4 wheels.
I use AKA glue and carefully lift the bead up so enough glue completely seats to the inner lip of the wheel as I apply the glue to the wheel and then let the rubber press onto the bead of the wheel.
After setting all 4 tires with CA, I'll go back and spot check for any holes by slightly pulling back the rubber to expose any weak areas and fill the voids with a drop or two where necessary.
I've mounted the tires within 2 hours of racing on a cool day with ambient temps around 66° and running a 17.5T motor. The traction is very high at Thornhill Jr, so the tires usually go bald after 4-5 heats of racing. It's possible that I don't get enough runs to see the beads peeling off because I go through tires so quickly?
I raced at OCRC a few weeks back and couldn't help but to notice how little tire wear they've got going with their mister system. I'd be curious to learn about how many heats of racing before the peeling starts to occur for you as well?
TIA
